Question about HP LaserJet 3330 All-In-One Printer
Scanner error message hp laserjet 3030
When I turn it on I get "scanner error turn off turn on" message. I've turned it off and on..I've unplugged it from the wall and plugged it back in. I currently do not have it hooked to a computer, I just use it as a copier.
The scanner bulb keeps moving to and fro until it display a message to turn of the printer with a sound warning.
  • 2 more comments
  • stug477 Aug 14, 2008
    Own unit since August 2003. Has been floorless in performance. Today I tried photo coping and I received error message "Scanner error - power off and power on". I did so many times to no evail. Googled HP Laserjet 3330 and made my way to FixYa for trouble shooting. Low and behold your remedy worked perfectly. Flashlight reveal a very dirty mirror. Q-tip worked. Bravo to you! Stu
  • J Radtke
    J Radtke Dec 22, 2008
    Cleaning the scanner mirror of my 6 year old HP 3310 solved this problem. Many thanks to jvgough for telling how to accomplish this with minimal disassembly. I was afraid of tearing up the belt, so used the on/off method of moving scanner; this process took about 15 cycles, so be patient. Dust on mirror was very fine, and looked like a film. Flashlight very helpful to see imporvement.
  • Anonymous Jan 04, 2009
    thanks, this really worked
  • Rockson Feb 23, 2012
    This has solved my scanner problem. Thank you very much!
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Posted on Jul 23, 2008
HP LaserJet 3030 showing "Upgrade Error - Call HP
This is very good & rugged printer better repair it, another five years service it will gives you. Just replace formatter assm P/No: Q2664-60001.
Sep 23, 2011 | HP LaserJet 3030 All-In-One Printer
HPLJ 3030 "Scanner Error -
Hi, unplugged its data cables for two hours. It exists inside the printer right or left hand depends on model. After two hours replug and you will see that your problem will have been fixed.
Best of Luck
Aug 28, 2011 | HP LaserJet 3030 All-In-One Printer
Scanner error power on power off message come
the scanner under the glass has a problem. turn the machine on with the top cover open and see if you notice the scanner moving either to the left or right.
Mar 05, 2011 | HP LaserJet 3030 All-In-One Printer
Will not print. Message says
Your scanner bulb is not warming up. It would cost more to repair it than buying a new printer.
Nov 29, 2009 | HP LaserJet 3030 All-In-One Printer
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
3030 hp all in printer scanner problem
dir
we have a laserjet printer. but he is not working. acually sacanner is not working
rahul
Sep 09, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Apr 04, 2008 | HP LaserJet 3030 All-In-One Printer
HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Scanner problem of hp laserjet 3030 all in one
Try unplugging the cord to the printer and wait a few seconds and re-plug the cord again , print what ya have to print again/hope this helps .
Dec 01, 2007 | HP ScanJet 3200C Flatbed Scanner
HP LaserJet 3330 All-In-One Printer Logo
2,076 people viewed this question
Seeker5211
Seeker5211
