Nokia N70 Cellular Phone Logo
Posted on Jul 14, 2008
Problem of blockage
My mobile blocks from time to time
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 09, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
53
Points
Unable to open cell phone because i forgot passward
Anonymous
Level 1:
  • Posted on Jul 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
53
Points
Allwas hanging my mobial
Bush washer dryer model WDNSX86W just stopped E21 code now it's started with E10 what do I do
Error 10 (E10) Water drain time out or failure The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Error 21 (E21) Not drained in time allowed - washing machine fails to drain water
Tubes blocks solutions ki only ivf treatment okatieee avvutunda? Dr. Garu
Common reasons for blocked fallopian tubes include scar tissue, infection, and pelvic adhesions.
If your fallopian tubes are blocked by large amounts of scar tissue or adhesions, treatment to remove the blockages may not be possible. Surgery to repair tubes damaged by ectopic pregnancy or infection may be an option. If a blockage is caused because part of the fallopian tube is damaged, a surgeon can remove the damaged part and connect the two healthy parts.
It's possible to get pregnant following treatment for blocked fallopian tubes. Your chances for pregnancy will depend on the treatment method and the severity of the block. Most of the times people with blocked tubes refers to IVF treatment by IVF Specialist
2helpful
2answers
Meri zong ki sim block ho gai hai pin code ki wajah se to kya ap help kar sakty hain
If your SIM got blocked, it will be asking you the PUK number. Call the customer care of your mobile operator from other no., and ask for the PUK no. Also brief the customer care regarding your SIM blockage, due to pin code.
May 01, 2013 • zong.com
My kitchen sink blocked
You show the dishwasher yet you complain about the kitchen sink being blocked. If the dishwasher is also blocked then the blockage is below the trap on the sink. If both are blocked then the blockage is after their drain pipes meet under the floor....good luck!
Nov 08, 2012 • Dishwashers
1helpful
Fisher Payke Intuitive Eco Washer isn't draining or spinning error code 37
Hi - the drain pump is blocked- empty the machine and scoop as much H2O out, turn power off - tilt backwarsd - 60-75 degrees, locate the pump and unplug the connector and earth wire, locate the lock on the pump a plastic clip, force outward and turn at same time the pump left or right to remove it . check for blockages - if no blockage found then the pump is on the way out, if you are lucky the and its blocked - put it back together & should be ok.
Our Neff dishwasher is blocked, we have looked at the back of it and can see the blockage but dont know how to remove it
time to get down and dirty get a WIRE HANGER unwrap that bad boy and watch him work use that to remove any blockages also works for those stubborn sink drains as well
1helpful
2answers
I have a gms8 furnace that will not light. The error code that I get is 3 fast blinks
Sorry to read about your problem, I hope this helps you out.
3 Blinks represent a problem with the combustion fan, pressure switch or a vent blockage.
if you have snow, it could be blocking the intake vent. if not that, most likely a defective preassure switch.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
1helpful
Clothes do not dry in the time they should and most time they don't dry. i got my dryer in may of 08
Try cleaning out the lint filter and if that isn't it, check the hose that goes from the back of the machine to a vent outside. Be sure the outside vent isn't blocked by anything. It could be blocked by something in front of it or something "living" in it. There could also be a blockage of lint . This could require the removal of the outside vent and actually checking it for blockage. Any further questions and you can ask me via email at dw6_edwrds at yahoo dot com.
1helpful
I don'tknow how to block a contact on a lg arena phone
please follow the steps carefully
  1. Step 1 Call the T-Mobile customer servicemag-glass_10x10.gif phone number located on your phone bill. Tell them you would like to hear about T-Mobile's call blocking service. The customer service then tells you how you can block all the calls coming from your T-Mobile cell phone by adding this service to your plan. When you select this service, anytime you dial a number from your T-Mobile cell phone, the number will come up Restricted on the call receiver's caller ID.
  2. Step 2 Dial *67 prior to any number on your T-Mobile phone that you want to block, if you want to just block one call at a time and choose which numbers you dial are blocked. This is another way you can call someone and to have it appear as a Restricted call on the other end.
  3. Step 3 Program your T-Mobile phone to block all calls to any one individual. Do this by tapping Add a Contact on your T-Mobile phone. Type in the name of the person you want to call. Then tap Add Phone Number. Punch in *67 then the number.
  4. Step 4 Tap the person's name to call him, when you have the person's number programmed into your phone with the *67 first. Every time you tap the person's name, you will be calling him from a blocked number.
hope you dooooo...
please rate me
thank you
6helpful
2answers
My DC05 Dyson suction has stopped...there are no blockages, the seals are good, there seems to be more suction coming from a yellow box which is situated at the top of the removable cannister. There is...
My Dyson had exactly the same problem. I found the problem was caused by a blockage in the hose. Take the hose out where it joins the cleaner (it will come out if you pull it downwards gently) and take the hose out of the handle by squeezing the yellow buttons on either side. I pushed a rubber alkathene pipe down and found a piece of plastic was blocking it even though at first I was sure it wasn't blocked.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
