Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Print color the printer does not print the correct color. I asked for black and red and got yellow!
    Problem Solver:
  • 9 Answers
I had a similar problem a while back so i changed the cartridges, but that didn't work. Then, I used every cleaning option on the printer at least 5 or 6 times and it started to work fine.
Posted on Jul 27, 2008
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the...
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Dec 23, 2011 | MicroBoards PF-3 InkJet Printer
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
No red
the color red is a mix of two color. so run the cleaning tool on the printer
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
WHEN PRINTING THE COLOR IS VERY WEAK
You have to disassemble the printer and clean the prisms inside the black box within the printer. The prism for the red and yellow colors are near the bottom and face up, so they easily collect dust buildup, thereby causing weak or striped printing of these colors.
Mar 03, 2009 | HP LaserJet 2605DTN Color Printer
Cyan ink new cartridge but will not print correctly
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Brother MFC-3240C All-In-One InkJet...
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
