Question about Panasonic Microwave Ovens
When using and setting the timer (i.e. 2:00 mins), microwave would stop after 25 seconds and no heat. Please help. Thanks!
  • Panasonic Master
  • 9,098 Answers
I bet it's 22 seconds. The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Panasonic microwave problem help needed
Dan, That unit has an inverter, that is the power source for the part that puts out the Microwave energy called the Magnetron. The inverters are expensive and I stopped doing warranty work for Panasonic beacuse of them. Some pencil pusher somewhere though it was a great idea to replace 3 common fairly inexpensive parts. with that dang inverter. Microwaves have come down a lot in cost, I would buy a new one without an inverter. Sorry, wish I had better suggestions, I DO NOT LIKE THEM. LOL Sorry! Panasonic and their distributors are always out of them and there so expensive no one wants to stock them. I have had new ones sent to me that were already bad.
Aug 20, 2017 | Microwave Ovens
Stops working after 20 seconds
The magnetron is over heating causing the thermal fuse to open to cut power, the only option is replace the part, but keep in mind it is the most expensive item to install.
May 07, 2012 | Bosch HMT9626GB Microwave Oven
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Stops working after 5 mins
make sure it has a good airflow around it, check the vents to see they are not blocked off by some object or dust. I suspect the safety sendor is turning the unit off to perevent overheating.
Microwaves that are contained in nooks and cabinets suffer from this problem regularly
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Microwave Ovens
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Hi Just received new Whirlpool Max 25 microwave. It all checked out fine first of all - I set the clock and the timer ok and tested by heating a mug of water and it worked fine. I unplugged it to move it...
It sounds like there may be a misaligned door switch mount or door hinge.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer again to get it fixed free.
You will have to contact Whirlpool again. You can call the number in the manual or visit the Web site they might give their.
I would ask for their nearest authorized service center.
Sep 03, 2008 | Whirlpool Microwave Ovens
Help, my Panasonic NNA724M Combination Oven will no longer microwave. I can set the microwave going but after 20ish seconds the microwave stops and timer is replaced by the clock, without any audible...
This is an inverter model, and when they stop after 20 seconds, it usually means a problem in the high voltage section, either the inverter or the magnetron.
If you don't have experience troubleshooting high voltage inverters, I recommend calling a pro.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 01, 2008 | Microwave Ovens
Microwave Ovens Logo
245 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
