Question about Roper RUD5000H Dishwasher
Water in bottom
There is standing water on the bottom in the back where it look like it drains. Would this indicate a clog? What should I do?
  • taziah Feb 06, 2009
    same probolem
    An expert whose answer gotĀ voted for 100 times.
  • 67 Answers
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
If this helps please vote me a fix ya
Posted on Jul 14, 2008
Kenmore 58715162400. Does not drain water. Water stands in bottom after wash cycles. Have to **** water out with shop vac hooked to the drain line to the sink.
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Mar 13, 2011 | Kenmore Dishwashers
Standing water in bottom of unit and won't drain.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Jan 25, 2011 | Dishwashers
Water draining into bottom of freezer and freezing.
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jan 08, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Ice builds up in freezer bottom pan, not going down the drain tube. Is this an indicator of the defrost timer not working correctly, and if so where is the drfrost timer on a ETIFTTXKT02 model?
Defrost timer is working or there would not be water/ice in the bottom pan (as you describe it.). Check that the drain tube from the pan to the bottom evaproation tray under the refrigerator is clear of restriction.
Dec 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Dishwasher not emptying at the end of its cycle. If water siphoned out will work temporarily then fails again, with water remaining standing inside machine. Check water indicator light is on, goes off when...
Not sure of your light indicator; check the manual. But fyi there should be a little water left in, so the rubber seal doesn't dry out. More than that, and could be clogged drain or bad solenoid, which tells it to open and drain. See:
Sep 17, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
Jun 16, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
May 19, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Roper RUD5000H Dishwasher Logo
363 people viewed this question
Top Roper Dishwashers Experts
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
