Question about Toshiba Satellite A60 Notebook
No boot with long continuos beep
When I starts my Laptop, one long beep can be listened and nothing else happend. The long beep is repeating after a while
  • Anonymous Jul 22, 2008
    i have a tosh a60 when i press the power button gives a long beep and no screen then shuts down?? help
  • muld3r Jul 27, 2008
    i have the same problem and tried 2 different rams. i dont think that both are faulty...
    Sergeant:
  • 457 Answers
You ram needs to be replaced
Posted on Jul 15, 2008
My PC running a Gigabyte GA-M55SLI-S4 motherboard won't boot up - it emits a continuos series of beeps: a 1sec beep with a 10sec pause then keeps repeating & cannot even get into Bios setup
Check your CPU make sure its placed correctly and that you don't have too much contact grease,you only need a very small amount.
If that's not the problem try re-seating your ram and video card.
Other then that look at the power supply could be under powered!
hope this has helped
Jan 22, 2011 | Gigabyte GA-M55SLI-S4 Motherboard
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Easynote laptop continuos beep
your laptop RAM has been faulty.pls replace it.
Aug 21, 2009 | Computers & Internet
My Laptop boots occasionally
Let me see if I understand this right!...you turn the power on, the lights come on, the hard this spins and nothing happends???...Does this happend always??? Has it ever taken you to windows since then? Does it ever stay on more than 2 secs?? does it shutdown afterwards?
let me know
Apr 04, 2009 | HP Compaq nc6000 Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
I have a presario compaq v3230AU lap top that does not boot.the power turns on but the screen remains blank.wat could be the problem.please advice
Hi there. It would help if you provided more info regarding your problem. The follwing would be good startpoints:
1. What was the last time you were able to do with the laptop?
2. Have you made changes [immediately] before the issue started happening?
3. How old is the PC?
4. What are its specifications (ie.CPU speed, memory type and size, OS, etc.)
5. Have you experienced this same problem before using the same computer, or on another computer?
Well, here's a shot in the dark. If the unit is, say more than 5 years old, it's probably a hardware defect. Meaning your unit's screen display data connection is already out of order. This usually happends to laptops with data connections too compactly embedded between the hinge of the laptop lid and chassis.
Mar 09, 2008 | Computers & Internet
Problem with on my boot
put ur XP cd and repair once thro recovery console ...
Dec 07, 2007 | Acer Aspire 1710 Notebook
Acer 1670 laptop will not boot in to bios
If what has happened is true, then the previous owner had killed the BIOS. He has tried to FLASH the BIOS and it failed. This then renderes the motherboard DEAD. Your only option is to try and find a replacement motherboard.
Aug 31, 2007 | Acer Aspire 3680 Laptop
Boot beeps
re check all inserted pci cards and all memory, reseat if necassary. Have you recently upgraded anything, if so remove. Continuos beeps can also indicate processor power failure.
Mar 19, 2007 | Soltek SL-65KV2-T Motherboard
Toshiba Satellite A60 Notebook Logo
347 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
