Question about Philips 60P8341 60" Rear Projection Television
Tv fix Our tv when turned off it won't come back on but the power button blinks, i think five times repeatedly. we can finally get it turned back on by plugging and unplugging repeatedly but are now afraid to turn it off. Help please!
  • Philips Master
  • 8,617 Answers
That is usually related to the LSB large signal board will eventually need replacement. Most repair shops will not troubleshoot the LSB at component level, they will opt for replacing the entire circuit board. If you need more info or help to locate a LSB board. please let me know.
Posted on Jul 14, 2008
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a mitsubishi model ws65809 big screen tv. When I turn power on it only stays on for 10 seconds then shuts off. I checked the fuse but fuse was fine.I want to know if I changed the lamp will it fix...
You will need to press the menu button and the input buttons on the TV both in together for five secoinds then count the two digit blink code from the power indicator. the blink sequence will repeat several times. let me know the sequence of the blinks.
May 30, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
MY REMOTE TURN THE TV ON, BUT IT TURN OF MY IT SELF. I CAN TURN THE TV ON BY POWER, BUT IT ALSO TURN IT SELF BACK OFF.
do the self check this set has, when power light goes off, ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT (DEVICE) BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH.
Watch the power light, it will blink a two digit error code=====most common is two blinks, two blinks a pause and it will repeat the code several times.
This is to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
SD TECH
Nov 10, 2010 | Mitsubishi WS-48313 48" Rear Projection...
Tv randomly shuts off
next time it shuts down and power light goes out--do the self check.
On front of set press and hold BOTH MENU AND INPUT BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH BUTTONS.
Power light (if an error is detected) will blink a two digit code.
Most common is 2 blinks, pause and 2 blinks---set if there is a error code will repeat it at least 5 times.
If you detect a error code, let me know and I will tell you what it means.
SD TECH
Jun 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55515 light blinking
Sounds like the remote is not programed correctly or the input sources have been changed.
Call the cable company and complain that it worked before they came and shoud work afterwards.
Mar 24, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
