THQ Jeopardy for Nintendo Wii Logo
Posted on Jan 16, 2011
Adding second remote for jeopardy so 2 people can play at the same time
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 17, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
224
Points
When in any game, when you are ready to add additional remotes, on player 1's remote, hit the center wii "home" symbol. Then at the bottom of the screen you will see the "remote settings" bar. Hover over it with player 1's remote, click it and follow the on screen directions. Hope this helps!
When I try to play jeopardy it goes to blue screen of death
Blue screen of death generally indicates a hardware problem. Does it happen with other resource intensive programs? I would lean towards a bad ram module, or possibly a bad on-board graphics processor (if you dont have a graphics card)
tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 • Televison & Video
I have dish network and an apex 1225 dvd player. i do not have a remote for the dvd player. i do however have a dish network platinum remote control. i am in need of the code to link this remote control to...
Try the steps below these processes are called a power scans, there is a different type for any equipment needed. This should take 5-6 minutes per item to program.
For DVD/VCR's:
1.) Press and hold the correct VCR/DVD button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
For TV's:
POWER SCAN
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
For any other equipment:
Power Scan AUX
1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
Press and release the large red Power button.
3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
With any of these methods verify the code works by trying several different functions for that equipment.
Daniel Busa
DISH Network
Customer Service
2helpful
I have a DELL with XP-Home Edition - version 2002 service pack 3, Intel(R) - Pentium(R) 4cpu 2.66ghz, 2.66ghz, 512 MB of RAM My daughter plays games and has 24 of them in the computer - she tells me I...
Hello, Jim.
Dell's official position is that the maximum memory for this PC is 1 GB. But, it may be able to support 2 GB, per Intel's specs.
But, to answer your question - yes - you can increase your memory amount to 1 GB. Since the system has 2 memory slots, you could conceivably have (2) 512KB modules (total 1 GB). If your system already has 1 module of 512 KB, you could add another. Just be certain it's the same type and speed.
Or, you could have a 1 GB module.
I don't think that your computer's life is in jeopardy, but additional memory always helps the speed of your computer.
Hope this helps.
Just added a new wii controller now I have 2. I activated but when I try to use it to play tennis against my husband only his remote works mine wont swing. The cursor is on the second one is red and lloks...
When you are on the screen where you select number of games, use the second WiiMote to click on the two characters on one of the sides of the screen. that will assign them to the player 2 controller. Hope this helps =)
1helpful
Will only play copied disks. will not play
this is because you used original disk`s from different areas. Try this:
1. Open tray and remove any disks in tray.
2. Close tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.
6. Press ENTER on remote. (The player will power off.)
7. Switch on power from remote.
8. Player is now Region Free.
2answers
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Second controller doesn't recognize accelerate, reverse works
Try resynchornizing it to your Wii again. If this doesnt not work, you may have a defective Wii Remote. You should consider replacing if synchronizing it does not work.
Closed Captioning
Turn your DVD player on with no disc inside. Use your remote and press the Setup button. From there go to audio and there should be some settings for closed captioning.
1helpful
3answers
Jeopardy
I downloaded this patch from Encore's website and ran it and the games runs perfectly now! Hope this helps!!!!! Have a wonderful day!!!!!
http://support.encoreusa.com/kb.asp?id=590
Top THQ Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
MegaByteMe
MegaByteMe
Mark Ultra
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
