Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
No lights no coffee nothing
Hi Johnny, our machine was working perfectly one day but failed to start the next. There are no lights on the panel. Power and fuses ok. Dump box, drip tray, front door and brew mechanism are all seated correctly. Please help...............Pete and Lizzy
  • petenliz Jul 15, 2008
    As stated in my original post, power and fuses checked and ok. If it was within warranty it would be back at the shop by now..........
  • Saeco Master
  • 19,396 Answers
You need to check the power supply inside the machine, if there is no power at all is a power problem.
Posted on Jul 15, 2008
  • 6,487 Answers
Try this:
Testing a thermal fuse in the heating element.
Unplug the unit from the electrical receptacle.
Remove the pot and basket. Remove or tape closed the water reservoir lid.
Turn the appliance over and remove all screws that secure the case halves. Lift off the case to expose the heating element and controls.
Inspect the control cavity to determine if the solution is simple: disconnected wire, debris, etc. If so, fix, reassemble, and test. Otherwise, continue with the next step.
Use a multimeter to test the warming and heating elements, and the switch, thermostat, and timer .Replace any defective parts or decide to replace the appliance, as appropriate.
Reassemble the appliance and reinstall the pot and basket.
Fill the water reservoir approximately half full, then plug in and turn on the coffee maker to test its operation.
Disassemble and test a percolator coffee maker:
Testing a switch with a multimeter. The switch should get a reading of infinite when off and little or no resistance when on.
Remove the basket, stem, and lid.
Turn the appliance over and remove all screws that secure the base. Lift off the base to expose the heating element and controls.
Inspect the control cavity to determine if the solution is simple: bad seals, disconnected wire, debris, etc. If you find a problem, fix, reassemble, and test. Otherwise, continue with the next step.
Reassemble the appliance and reinstall the stem, basket, and lid.
Fill the coffee maker to approximately half full, then plug in and turn it on to test its operation.
Hope that helps.........
Posted on Jul 14, 2008
    Genius:
  • 1,447 Answers
Hi-
Does it turn on? have you tried replacing the fuse? try a different power surge and cable if you have extra.
And if product is still within warranty, call manufacturer for replacement if steps above doesn't help. Thanks for using Fixya!
Keep us posted for any progress.
I have no lights on espresso shot panel?
there is a problem existing in the board (IC) you need to replace the board
May 24, 2015 | Nuova Simonelli Premier Maxi Espresso...
Mr coffee wont turn on
Its a bad coffee maker, return to place of purchase for refund or replacement.
Nov 19, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
My Keurig will not turn on...no lights flashing, nothing...I used it two days ago and it was fine...i came back into work and it wouldn't do anything. I tried unplugging it and leaving it unplugged and...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 15, 2011 | Keurig Elite B40 Coffee Maker
One day the brewer worked fine the next there was no power. Tried unpluging it and waiting then plugged it back still nothing. Not sure what the next step is. Does the machine have a rest on it? What are...
heatman101
Aug 27, 2011 | Keurig Elite B40 Coffee Maker
The machine was working perfect. This morning there was no power light on and nothing is working. Checked the plug and it works with other appliance. .
heatman101
Jul 14, 2011 | Keurig Elite B40 Coffee Maker
Dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
No water
Sorry for not replying you to message, I was not receiving any emails from Fixya.
I hope you were able to get your machine working again.
If you still need help, you can contact me directly at johnny@cerinicoffee.com
Thanks,
Cerini Coffee
www.CeriniCoffee.com
Sep 24, 2008 | Saeco Classico Espresso Machine
No coffee comes out from the coffe machine
The grind may be too fine. The Brew unit is plugged and needs service. The spout joining the boiler to the brew unit is broken. The unit may be plugged with scale.
Jul 24, 2007 | Saeco Magic De Luxe Espresso Machine
Won't make coffee-doesn't appear to turn on.
Same thing here, just call the 1-800-726-0190, they will send you out a new one. You'll have to pay a $10.00 shipping and return the old one. You should have your new coffee maker in 7 - 10 days, customer service was nice and very helpful. No complaints here except, what do I do for coffee for the next 7 - 10 days?????????? LOL
Jun 06, 2007 | Cuisinart DCC-2000
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
159 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
