Question about Haier HDN655E Dehumidifier
Where can I find the fuse on the panel?
I have Haier HDN655E dehumidifier and bought 1 year back. Suddenly, one day power does show on the panel and everything looks dead on the panel. After reading these solution, my problem could be fuse also but I am not able to find the fuse. Please provide some more description, where should I look for the fuse and how should i find out which fuse is blown
Thanks
uddins43026
  • Anonymous Jul 21, 2008
    Same problem. I've checked Radio Shack and they don't have anything like this, and can't order anhything like this.
Tiewraps.com on the internet, you can purchase a 10 pack of 250volt 12amp fuses. AG-12
Posted on Aug 02, 2008
Haier HDN655E - water does not drain out of hose
check the hose connection,when new these units have a knock-out plug where the hose goes so if your only going to use the bucket and not the hose it wont run out the hose connection
Aug 01, 2010 | Haier HDN655E Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
Fuse location
bottom left of board. has a blue plastic covering. if you find out why it blows fuses please post. baby need diapers not a new dehumidifier!!!!
Jul 15, 2009 | Haier HDN655E Dehumidifier
Fuse size for HDN655E
Haier Part No. AC-3050-02 or AC305002. Google it. Three vendors sell this fuse ranging from $1.73-$1.95 each.
Jun 08, 2009 | Haier HDN655E Dehumidifier
Haier Dehumidifier stuck on 45
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 29, 2008 | Haier HDN655E Dehumidifier
Haier HDN305 humidifier
It's on the right side under blue plastic cover.
Jun 13, 2008 | Haier HDN655E Dehumidifier
Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
Aug 21, 2007 | Haier HDN655E Dehumidifier
Haier HDN655E Dehumidifier Logo
690 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
