Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Tv fix Did you ever get a fix for your tv
  • Philips Master
  • 3,459 Answers
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jul 16, 2008
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Why does picture have lines of different colors?
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
My Panasonic TV HDTV Model PT-56TW53 - 52 inches / 1080i I bought the projection TV in October 2003.
This TV has reached well beyond its normal lifespan for the TV type and size. The new LED/LCD displays are so much better that you will wonder why you haven't replaced before now.
Jun 29, 2017 | Televison & Video
I want to fix my lg tv to a bracket but I don't know what screw/ bolts i can use and fix the bracket to the back of the tv thanks.
the screws are philips round head type fine thread u will need to go to a tv bracket dealer shop specify the size of the tv and u will be sold the bracket which comes with the standard screws for mounting
Jul 11, 2013 | Televison & Video
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Can the flat screen tv is fixed when soneone
No,the LCD screen panel are broken right?The LCD screen are 90% of the tv,will cost the same as a new tv to do the replacement of the LCD screen.Now the tv,not worth as a whole tv anymore.Tv only can be salvage for electronic boards only now.
Jun 25, 2010 | Samsung 52 in. LCD Flat-Panel HDTV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
RCA F27683GY 27" TV
I bet both TV's are connected to cable TV? This was a problem and required different fixes. There was a law suit against RCA for this issue as they said there was nothing wrong with thier TV's that it was a cable issue. You will probably have to contact a local TV shop for repairs as just audio boards won't fix the problem.
Mar 22, 2007 | RCA F27683GY 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
