Question about LG WM-2277HW Front Load Washer
Water Leaking from pre-wash and main wash cold water solenoid
Noticed a small water puddle on the fllor in front of the washer. Did the usual investigation and noticed the leak was coming from the bottom of both the pre-wash and main wash solonids.
I took the solenoids off, moved the springs, plastic and metal inserts as well as rubber washer beneath. Reassembled the units and still a small, now slower drip leak.
Any idea if I need to change the entire solenoids or only the small rubber gasket undert he unit? Besides this the unit still seems to operate fine.
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Posted on Jul 21, 2008
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Water continuously seeps into the detergent dispenser, then into the tub. OVer night, the tub is half full, wife opens the door, and water spills all over the floor?
It sounds like you have a leaking solenoid valve, located where the hoses connect to the machine. Find out which one it is by shutting of the water to one side (either the hot or cold) and wait. If the washer fills, the hose that is open is the culprit. Chances are that the leaking solenoid is the one that you use most often (say, if you always wash with cold water). Here's what you need to do after that:
1. Drain down the tub. Easiest way: run a short cycle.
2. Make sure that both water valves (at the wall) are closed. Unplug the washer.
3. Disconnect the hoses from the machine (Caution:Water!). Catch the water in a bucket or pot.
4. Gain access to the solenoid valve that you determined to be leaking by. This is usually done by removing the back panel.
5. Make a sketch of the solenoid, showing which wire goes where, what color it is, etc. This helps in the re-assembly.
6. Remove the solenoid. Take it, along with your make and model number to your local appliance parts supply store.
7. Install your new solenoid.
Best regards, --W/D--
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I ran a load & after switching the wash i noticed a puddle of water sitting at the bottom of the washer
water puddles usually indicate a leaking water pump-check the gaskets to make sure they are sealed before replacing the pump
Sep 17, 2010 | Kenmore HE2 Plus Front Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag washer
dsands, if the noise is like a train roaring then it could be the bearing. The fact that you have some water leaking leads me to believe that the tub seal leaked onto the bearing. Now this could be covered under the 5 year warranty, depending on the tech that comes out. Another possiblility is that something is caught in the pump and it is leaking. You would have to open the front panel to get a look. On these Maytags if something gets in that pump like a button etc., they will scream like a raped ape. With out being there my gut feeling tells me the seals leaking and ruined the bearing. Catriver.
Dec 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
LG WM-2277HW Front Load Washer Logo
422 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
