Question about Boston Acoustics BA735 Computer Speakers
More info for you
I apologize for not giving enough info the first time. I should've known better but I think my mind was worn out by then. I contacted Boston Acoustics and they want me to send it to them for repairs which I'm sure will have a ridiculous price tag. They wouldn't give me the part number or any info at all. I live in Point Pleasant, WV but as for parts dealers I'm most likely better off shopping online. As for the specs on the potentiometer all I can give you is what I've figured out... 50k -- the total shaft is 15cm in length, the first 5cm of that is threaded for attachment -- diameter of shaft looks to be 1/8" -- most length of the shaft is flattened a bit down one side, looks like a "C" -- the pot is a bit rectangular with 3 main pins and 2 board attachment pins -- measures about 3/8"W x 3/16"thick x 7/16L -- there is also a "B" near the 50k marking and a number along the side of the pot 9924. Hopefully this info is more helpful!! I guess my internet skills are not so good since I've had no luck finging this thing. Thanks again!!
  • 2,130 Answers
The pot is a 50k ohm audio taper pot with an integrated switch. The shaft is called a "D" shaft and is used with knobs that have a set screw. The 3 pins are the for the resistance with the center pin being the wiper. The other two pins are for the on & off switch.
It's going to be hard to find the exact replacement without knowing the manufacturer of the pot. It looks like the one you have is soldered to a PC board and the pins have to be in the right spot on the new pot order to match up with the PC board.
What you can do is buy one with solder terminals. Rotate the pot so that the terminals are facing up and just solder wires from the terminals to the PC board. If the shaft is to long, you can cut it down with a hacksaw.
I am looking for sites for you to call. here's a few I found thus far:
http://www.farnsworthelectronics.com/potentiometers.htm
http://www.ctscorp.com/components/potentiometers.htm
Posted on Jul 15, 2008
Yamaha pw80
The only thing I can think of is the forks that move the gears in the transmission could have been bent at some point, or a bearing or a bearing surface as those are only things you did not mention. The other possibility is that there may be a misalignment of the gears causing them to catch, or that a spacer is worn. Japanese transmissions are generally never the source of the problem, but you had better know what you are doing if you ever have to open one up. /they need ti be reassembled using feeler gauges and painstaking care. I have even known of a reused gasket causing a problem but on a much larger bike, I think you may have to take that one to a shop to diagnose, as without looking at it and checking all the plays and adjustments myself, I could not give you a better idea.
Oct 30, 2013 | Motorcycles
Wont shift into third gear and also sometimes hesitates when I accelerate (as if it was being flooded).
hi, My first thought on this is that you may have a linkage issue. your shifter may read that you are in drive, but you may only be in 2nd gear. Check it out. bump it up so it will look like you are putting the car into nutral, but be careful to not go too far and put it in reverse. if that is not the issue, I would suggest that your car has a brain that knows that the transmition has a problem with 3rd gear and simply wont let it shift into 3rd because maybe there is no 3rd. like the band could be broken. post your results if ya dont mind. I am interested to hear more. I hope this helps ya. Tim
Oct 07, 2012 | Cars & Trucks
I've got slippage on my drive train- what do you suggest
It's probably worn cogs or a worn chain. A bike shop can give you a better idea of what is going on.
Aug 02, 2011 | Cycling
Missing print
im not sure what you're asking?
But we can start with operating system, The lp2844 works well with vista and x but has a known problem printing items on windows 7,
For example if your trying to print postage from paypal and using windows 7 it will mess up every-time.
If you give me more info I may be able to better help you.
Sep 13, 2010 | Zebra LP 2844 Thermal Printer
Golf 1 14i sounds like a short
could you give me more info plz
Jul 30, 2008 | 2004 Volkswagen Golf
Water to dishwasher not hot enough
The 737 model could run on even lower temperature (80F). Given time, the unit will heat up the water. the trick is to give it time.
That model is made for commercial use, not really for residential. It will not fully drain every cycles. The important thing to keep in mind is to empty the dishwasher (turn it off, pull the stand-pipe out, and drain) every night and left empty. When you want to use the unit, put the plug back in and turn it on, wait 20 to 30 minutes and it should be ready.
Robert Marsolais
Jul 28, 2008 | Jet Tech Systems 24 in. 737 Free-standing...
Replace worn parts and ware to find them
You didn't give a location, so I cant offer someone to help. I do know that the magnetic switch, otherwise known as a contactor, chatters because its not getting enough voltage at the control coil. It should have a label listing the coil voltage on it, check the power source and go from there.
Mar 18, 2008 | Dayton (4LX41) Heater
What is better?
If I had to pick based on specs and pictures, I might go for the Sony's over the JVCs. But listening to each of them is really the only way to know for sure.
Keep in mind, neither Sony nor JVC are really known for their car speakers. You might be able to find something a bit better for a similar price from Infinity, Boston Acoustics, Polk, or Pioneer.
Mar 14, 2008 | Car Audio & Video
Boston Acoustics BA735 Computer Speakers Logo
146 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
