Question about GE Spacemaker JVM1640SJ Microwave Oven
No power on GE space maker xl 1800
I have built in Microwave oven above my stove but it has no power I unplugged replugged nothing I checked the circuit it is fine I can the plug for other appliances. Please help.
Thanks.
V
vinodk2005@gmail.com
  • tim9888 Jul 15, 2008
    I have the same problem with the JVM 1660... It died after just 2.5 years of very light useage...
    tB
  • GE Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
Micro spacemaker XL 1800 does nothing like not getting power not at panel or or outlet there good
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have Spacemaker XL 1800, which overheated tonight (accidentally set "heat" rather than "timer" :-() and went "dead"/completely black. It is now cool; I have unplugged and replugged but nothing is...
usually these units reset automatically after a shock! It takes time for the over load circuit to reinstate power. If by 5 hours you have no luck , then the internal ceramic fuse has blown ( under top of cover)
Sep 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
DEMO MODE
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
100 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
