Looking for the NETGEAR WNR1000 default password?
You probably have little reason to access your router on a regular basis so don't feel too bad
f you've forgotten the WNR1000 default password.
However, when you're troubleshooting a network problem and need to get in to the device,
the WNR1000 default password suddenly becomes very important.
For most versions of the NETGEAR WNR1000, the default password is password. As with most passwords,
the WNR1000 default password is case sensitive
Be sure to change the default router password on your WNR1000 to something more secure as soon as you're in.
Then use a free password manager so you'll never forget your new WNR1000 password
hope this helps
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Unfortunately, there is no way to recover a lost or forgotten password
from a router or access point; you will need to reset the device to
factory defaults. However, once the device is reset to factory defaults,
you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
