Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse
OR a thermal cut-off fuse,
but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
