Pitney Bowes 1630 phone/fax/copy displaying "error 76 offline". How do I fix this? Was working fine and then POW!! this showed up.
  • Anonymous Sep 03, 2008
    error 76 message
  • Anonymous Sep 25, 2008
    Same issue
5 Suggested Answers
SOURCE: how to connect pitney bowes 1630 to PC
you will a usb cable and driver software.should not have any other problems
Posted on May 07, 2008
  • 18 Answers
SOURCE: How to print Speed dial numbers programmed for
I believe you press , features 1 , 7 , 3 enter then the send receive key to print.
Posted on Aug 26, 2009
  • 149 Answers
SOURCE: Pitney bowes fax machine model 1630 has 76 error
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Posted on Nov 28, 2009
  • 149 Answers
SOURCE: I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Posted on Feb 24, 2010
I have a Pitney Bowes Model 1630 copier / printer, Message "Printer Jam offline" .No Paper jamed in unit...How can I fix ?
A sensor is probably blocked or a torn piece that cannot be seen is in there. Take a can of air to it. Also turn it off and turn it back on for added measure.
Mar 09, 2011 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
How to repair error 76 of pitney
the fuser lamp is broken. call 18002435556 fro service. not user friendly to repair.
Nov 07, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
Jun 09, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
How to connect pitney bowes 1630 to PC
May 06, 2008 | Office Equipment & Supplies
Pitney Bowes 9720 Fax Machine...
ok " if you take out the paper tray and look where it goes , you will see little metal finger, it goes to a micro switch , that switch
could be bad, and it can be replaced.
Jan 21, 2008 | Pitney Bowes 9920 Plain Paper Fax
144 people viewed this question
jasbo
jasbo
