Question about Acer Computers & Internet
Computer is saying I have no wireless device?????
  • jaamd Jul 14, 2008
    I am using a laptop not a desktop....it is still saying I have no wireless device. The wireless internet worked fine all along and then a couple of days ago it stopped. I contacted my isp and they said it has to do with the laptop not with their service. I really wish someone could help me fix this problem :-(
    President:
  • Acer Master
  • 1,314 Answers
Since this is a desktop, wireless devices are not standard. Did you install one? If you did, is it inside the computer? If it is, make sure it is completely in the slot inside the computer and hasn't come loose.
Thanks and please take a moment to rate as fixya.
Posted on Jul 14, 2008
  • Kevin Shafer
    Kevin Shafer Jul 15, 2008
    So why are you rating a thanks for trying? You put it in the desktop category so therefore I gave you advice for a desktop. Please rerate as helpful and I can proceed to troubleshoot your laptop.
Won't let me change from wired to wireless.
Make sure that the wireless button is not turned off. If there is a physical button, then you may want to push it into the opposite direction in order to get it working correctly. The other option is to click the "search the web and windwos" area of your task bar. Type in "wireless" then there should be an option that says " turn wireless device off" or "turn wireless device on". In your case, you will click the option that says "turn wireless device on". This should resolve your issue of not being able to switch between wired and wireless.
May 20, 2017 | Computers & Internet
When i connect my tiny usb 2.0 bluetooth edr dongle mini wireless adapter my pc says usb device not recognised can you help me resolve the problem please
Please update the USB 2.0 drivers and try to use the device. If you are using desktop machine then try to connect the device in back USB port.
Feb 18, 2012 | Tiny Computers Tiny USB 2.0 Bluetooth V2.0...
Wont connect and keeps saying connecting
Computers that connect with wireless signals transmit to allow capture from an alternate device within vicinity either server computer for example. Observe that the computer is functioning with available signals least attaining another device that has program features. In the situation that several computers at an area share network resources, wireless signal display as appearing least capturing resouces is indication of regular functionality only requires operator to request media resources from a recogniseable device. For example, the network establshiment that were an establishment gaurantees resources. in the instance with estabshing wireless requires recognising an alternate device to derive resourcefullness. Gaming devices that captures wireless signal make transmission attainable.
Feb 20, 2011 | LuckyWire
Hp ze4500 laptop I bought a new pcmcia wireless card installed driver cd. but card does nothing dosnt even light up. computer dosnt know its their.
COMPUTER DOESN'T RECOGNICE IT?
AFTER CONECT WIRELESS DEVICE YOUR COMPUTER NOT SOW A SIGNAL THAT SAY IF CONECTED OR NOT?
WHAT IS YOU WINDOWS SYSTEM XP?VISTA? WIN 7?
AFTER CONNECT WIRELESS DEVICE. GO TO START/RIGHT CLICK ON COMPUTER AND GO TO PROPERTIS. CLICK DEVICE MANAGER AND LOOK FOR YOUR DEVICE. IF NOT THER .
YOUR PORT ARE NOT FUNCTIONAL OR WIRELESS DEVISE NOT WORKING
Feb 18, 2011 | Trendnet 108Mbps Wireless PC Card Wireless...
I have just recently had to reinstall Windows XP Home edition onto my computer and now i find that there are no network connections and i tried to create one that is exactly the same as the one that i have...
the drivers for your wireless card is not installed...
start > run > type--->>> devmgmt.msc and click ok...
you will see the device manager...
select network adapters on the list...
you must have the wireless card listed there...do a right click on wireless card and select properties, you will see the device status...the device status must say that "the device is working properly"
if you dont find the wireless card under network adapters then you will find it under other devices or unknown devices...or you can see an yellow exclamation mark or question mark in the device name...
it says the device driver is not installed properly...
you need to install the driver from the cd that is given by the computer manufacturer...if you dont have the cd then you need to download the drivers from the manufacturers site and install them on your computer...
if you dont find your device any where in device manager then it says that the device is not detected by your computer... in case of laptop you need to make sure that any switches for wireless card is turned ON..
have a look at my routers and other essential tips...
Aug 11, 2010 | Computers & Internet
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
How do you connect WIndows Vista to Windows 7 through ADHOC?
Dec 04, 2009 | Computers & Internet
Wireless connection: computer says device unplugged, but it's not. All the settings are correct, but still cannot connect to home network. Used to work before computer software (Win XP Media Edition) was...
Hello Michael,
Windows XP Media Center Edition (MCE) does not normally say cable unplugged. I think you are looking at your Local Area Network (LAN) connection. Make sure your wireless card drivers are installed, and the device is enabled.
1. Click Start
2. Right Click My Computer
3. Click Manage
4. Select Device Manager in Left Column of Newly Opened Window.
Make sure your wireless card does not have a yellow caution sign on it, and make sure your wireless card also does not have a red X. (If you when you select device manager, no devices show that right away, then it should be ok)
If there is a yellow caution sign, you may need to install drivers or your device is having some sort of issue.
If there is a red 'X' on the device, right click the device, and select enable. Again verify there is no caution sign.
Make sure your wireless radio is also turned on.
Let me know if you need further assistance.
As a reminder, if this post helps, please rate it. Thankyou.
Feb 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Installed Linksys G router successfully on my own computer. Now I'm trying to connect a second computer for wireless internet and I'm getting an error message saying: The wizard cannot create a wireless...
1 make sure the wireless adapter is on.. (laptops have on off buttons for wireless)
2 make sure the drivers are installed for card in laptop
if not reinstall them..
check in device manager look for ! or ? in there if you see unknown device or cannot start messages reinstalled that device..
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
