Question about HP Computers & Internet
Have a hp sr190nx desktop w/6 usb ports. theres power to the ports but no data. any device inserted is not recognized
  • 781 Answers
Check bios to see if usb turned on. or start/control panel/system/hardware/check all drivers do not have yellow question mark by them if the do upgrade drivers
Posted on Jul 14, 2008
    Novelist:
  • 183 Answers
Reinstall the USB Driver software and try again.
How many USB ports does HP 6830S laptop have?
what is a 6830S, a compaq?
post full service tag we CAN NOT GUESS WHAT YOU HAVE,
ever.
you have the wrong chip driver loaded, IM SURE.
100%
that hub is inside your chip it has its own hub. not outside hub.
SURE !
it can refr, 6 easy !
some chips support 4,6 or 8 ports
many versions of this unstated laptop only run 4 of 6
the chips other pins are EMPTY (at MOBO levels)
and you must use the correct exact HP drivers,
matching your TAG data, 100%
but you did not.
or other did not. no idea the H3ll this laptop suffered cor
what OS is is this.
we know nothing at all but USB conflicts....
this is a service tag, what is yours? we can NOT GUESS
or our answers will be dead wrong, why is this so hard. looking and learning what is there.?
tag1-mpi5zxqxean5dzxlmi1i200s-4-0_0.jpg this is a DV5 base LT. not yours only you know what yours is.
Mar 15, 2017 | HP Compaq 6830s Notebook PC
When i insert the usb port in any machine it says the usb port has exceeded the power limits of it hub port
The is indication of an over storage data medium. Consider freeing up the data from the device to attain continue usage. Attempt to achieve connectivity from any available connection ports that may recognize the storage medium to allow for data freeing taking achieving regular functionalities.
Feb 02, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Hello i have hp rp5000 pc which have AGP port onboard but when i put graphic card in it it doesnt recognized it. I tried with another hp rp5000 bios but it doesnt work anyway-is there anysolution?
Erm, although the slot is labelled AGP1 (HEY HP Accelerated GRAPHICS Port 1 ???), it is not for a graphics card.
It is intended for an enhanced USB card that adds additional USB ports as well as 12volt and 24volt outputs.
The RP5000 was designed to be a POS (point of sale) unit and the additional ports were for devices such as barcode readers, handscanners and card readers to be plugged into.
Dec 25, 2009 | HP rp5000 PC Desktop
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
USB not recognized during printing and scanning
Some motherboard or operating systems have problems if you leave usb devices plugged in. They don't recognize that the device is still there and ignore it. These are referred to as "Legacy USB devices". There are a couple of things to try.
Make sure the problem isn't the printer if you can. If you have another computer just plug it in long enough to for the operating system to recognize something has been plugged in.
On this computer giving you the problem. unplug the usb cable and insert into a different USB port. Usually this is enough to "fix" it and make it usable.
Next is to unplug the usb and reboot the computer a few times. Then insert into a different usb port.
Past this point if it still isn't working then you need to go to control panel-system-hardware manager-usb devices and delete all entries under the usb header. Then reboot. This forces the operating system to find all the usb ports and reinstalls the drivers. Then plug in the usb and it should work again.
Oct 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Keyboard, mouse, front USBs,DVD recorder not working
It sound like your USB Ports is the problem. Go to the Hardware manager delete the USB Ports and then shutdown and power back up.
The system then should reinstall the USB Ports and associated drivers. If not the USB Ports were probably fried by the power outage.
Mar 30, 2009 | HP TouchSmart IQ770 PC Desktop
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Computers & Internet Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
