Question about Dell 922 All-In-One InkJet Printer
Dell Printer 924
Won't print, citing error #1203 I get an error message for Check owners manual on cartridge error 1203
I kept pressing menu, since it would not bring it up turned it off and on, it fixed itself, now it is printing.
Posted on Jul 16, 2008
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
The ink is printing out fine, but in cartridge warning window says they are empty, and then stopped printing saying to remove cartridges. Now printer has error of 1203 and won't work. It won't shut off,...
Try to remove the Ink Cartridge while printer is on then install it back after a minute. If you still getting the same error, possible the Ink Cartridge or Printer is faulty.
Jun 16, 2009 | Dell 924 All-in-One InkJet Printer
My dell printer 924 is giving me a message 1203
From what I was reading this error is caused by the contacts where your print cartridge connects being dirty or having old ink smeared on them. Pull out your ink cartridges and use a cloth with just a little dab of water to wipe any old ink off of these contacts.
To reset the error code you should be able to disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Apr 10, 2009 | Dell 924 All-in-One InkJet Printer
Trying to insert new ink catridges
I think it will do the trick for you try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Mar 31, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 dell printer head ;error 1203;change cartri... sane problem.help|| black will print but color wont print' correct cartridge is inserted ,still color wont print. warning was ignore that ink was low
Hey do a power drain by removing all the cables from the rear of the printer and then hold the power button on the printer of 15-20seconds with all the cable out connecting the printer... Then power on the printer if you still see the error code message displayed on the printer display screen do a nozzle clean in the computer, check on if the printer prints the nozzle clean test page perfectly.If not remove the cartridges and clean the nozzle of the cartridges with a clean cloth and be careful so that you do not destroy the copper contacts, clean the same you see on the carrier(where you place on the cartridges). I think this should work.
If not call in technical support.
Regards,
Dev,
Printer Technician.
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Dell Printer 924 error #1203
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
code 1203 in the middle of the page. good luck!
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
I am getting a message error 1203
Try this first see if it will help.
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell Printer 924
Please try this
or
Jun 24, 2008 | Dell 924 All-in-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
296 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
