Question about Toshiba Portege 3490CT Notebook
Hard drive replacement
There are two covers that look like the one, right or left side?
is there a diagram available?
  • romanarcher Jul 15, 2008
    Found the field manual.
    You have to take the main cover off, by unscrewing from the bottom. The hard drive is under the keyboard palm rest, lower right. Other parts have to be removed first.
    Thanks. Hope this helps for future reference.
  • 304 Answers
HD cover is usually closest to edge. very easy to replace if you are comfortable using a screwdriver.
Posted on Jul 15, 2008
How to remove hard drive from sony vaio pcg-2c1l
As you install new programs, rip music files from CDs or download data from the Internet, the hard drive on your Sony Vaio PCG laptop will eventually fill up and run out of room. You can replace the hard drive with a new one that has a larger capacity.
Power off the Sony Vaio PCG laptop, disconnect the power cord and then close the lid. Flip the computer over so that the bottom is facing up toward you. Press down on the raised latch that holds the battery into place and then pull the battery out of the laptop. Locate the five screws arranged in a square pattern on the right side of the laptop case. Take a screwdriver and remove all of the screws. Slide your fingernail or the tip of the screwdriver underneath the seam of the square plastic cover and lift it up. Grab the cover and remove it. Pull out the two screws that hold the hard drive onto the motherboard. Grab both ends of the hard drive and carefully pull it directly upward for about an inch so that you can see the cable connected to the motherboard. Disconnect the cable and then pull the hard drive the rest of the way out. Take out the four mounting screws that are located on both side edges of the hard drive. Take the replacement hard drive and install the mounting screws into its left and right sides. Plug the cable that runs from the motherboard into the corresponding port on the replacement hard drive. Check the direction of the new hard drive and lay it into the open slot in the same direction as the old hard drive. Use the two screws you pulled out earlier to hold it in place. Slide the cover piece back on and replace the five screws. Push the battery back into the laptop until the latch snaps into place. Hope this helps.
Dec 08, 2012 | Computers & Internet
Tip
How to replace a hard drive.
WARNING:when you replace a hard drive, you need to re install windows.
Step 1- unplug your computer and wait at least 24 hours before going to step 2
Step 2- find and take out all screws AFTER 24 hours.
Step 3- take off the cover. this may take time
Step 4- draw a diagram of the hard drive and all wires connected to it. use color codes.
Step 5- take out all cables that are plugged into the old drive. Take out the drive.
Step 6- Put the new drive in. follow the diagram you made (you did do that part, right?) to reconnect the cables.
Step 7- put the cover back on and screw it in place.
Step 8- install windows
on Jul 19, 2010 | Computers & Internet
I want to replace HDD on my HP ProBook 4510sand I don't know how help somone.
Hard Disk Drive removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data. CAUTION: Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Sep 19, 2010 | HP ProBook 4510s FM849UT Notebook
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
inside of the cover.
5. Remove the left cover.
6. Squeeze the white link lever on the left side.
7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
carefully snapping it out of place.
10. Remove one (1) grounding screw from the ETB harness.
11. Pull out the white wire holder by pushing it up.
12. Pull out the ETB connector.
13. Remove one (1) screw from each hinge cam on both sides.
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
Use the following procedure to replace the ETB.
1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left
side.
2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
May 23, 2010 | HP Color LaserJet 2600n Printer
How to remove my hard drive hp pavilion dv1000
Please follow these steps.
1) First of all, first unplug the power and also remove the battery.
2) Flip over your laptop. Make sure that when you are looking at the laptop bottom that the battery slot is located on the top portion.
3) On the lower right portion is the hard drive bay. You would notice two small screws on its left side. Loosen them up.
4) Lift the left side up and swing it to the right and remove the cover.
5) You would then notice a plastic or mylar tab on the left side lift the hard drive using that tab.
6) Slide the hard drive towards the left and it will be removed from the hard drive bay.
And that is it. That is how you remove your hard drive.
May 02, 2010 | HP Pavilion dv1000 Notebook
How to replace hard drive
Hi tstafford,
Before you begin any removal or installation procedures:
1. Shut down the notebook. If you are unsure whether the
notebook is off or in hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the notebook.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the notebook upside down with the front toward you.
b. Slide and hold the battery release latch 1 to the left.
(The front edge of the battery pack disengages from the
notebook.)
c. Lift the front edge of the battery pack 2 and swing
it back.
d. Remove the battery pack.
NOTE:
Reverse the above procedure to install the battery pack.
5. Loosen the two PM2.0×6.0 captive screws 1 that secure the hard drive cover to the notebook.
6. Lift the right side of the cover 2 and swing it to the left.
7. Remove the hard drive cover.
5. Grasp the mylar tab 1 on the hard drive and lift the hard
drive until it disconnects from the notebook.
6. Slide the hard drive 2 to the left and remove it from the hard drive bay.
7. Remove the four PM3.0×4.0 screws 1 that secure the
hard drive frame to the hard drive.
8. Lift the frame 2 straight up to remove it from the hard drive.
9. Slide the hard drive connector 3 off the hard drive.
See Below: Reverse the procedures to install:
Good Luck, and don't forget to leave a rating.
Thanks
Mark
Oct 17, 2009 | HP 418446-001 - HP Special Edition L2000...
How to replace the pollen filter in 2001 1.8 turbo New beetle
is the car left hand or right hand drive ?if it's right hand drive it is located on the passenger side under plastic cover slide the middle cover off then the left hand section just pops off under the cover there is another cover that is screwed down once you have got this off the pollen filter is on the left had side it has two clips at the front that u pull forward and the filter pulls up and out then u just do the reverse of what u did to re assemble if your car is left hand drive the filter will be on the right hand side good luck
Jun 30, 2009 | 2001 Volkswagen Beetle
Red light flashing on ps3.not over heated as only switched on for 2 minytes if that
OK - the problem could be with the hard drive connection - I have had the same problem after having moved the PS3 from one place to another. Apparently the same falshing red light fault indication is caused by either a poor hard drive connection or damaged hard drive.
Disconnect the powewr, remove the hard drive cover on the left hand side of the PS3, remove the blue screw (philips head), lift the metal latch and move to the right, the hard drive will disconnet and can be withdrawn from the unit.
Put it back in (carefully!) and slide it to the left, there is enough space on the left side of the drive to either slip in a finger or screw driver and ensure it is fully home.
Lower the metal clip back into place, replace the blue screw and cover and it should now boot up when powered on - if it doesn't, try the same procedure a couple of times - if this still doesn't clear the problem, it could be a faulty drive.
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Hard Drive Replacement
It is probably under the bottom left hand side cover of your laptop.
Look at this posting:
http://www.fixya.com/support/p264390-toshiba_satellite_m45_s265_pc_notebook/manual-14947/page-9
and notice the unlabeled cover with 2 ovals bottom left.
May 28, 2008 | Toshiba Satellite M45-S265 Notebook
Hi ! Ive got Packard Bell Notebook EasyNote GN45 ! I would like to put in bigger hard drive , but i cant take out old one ! Can u tell me how to do this ?
You should an anti static strap. It's available at any hardware store. First turn off unit. Unplug the ac adaptor.
Perform the following steps to remove the battery:
1. Make sure the power is off.
2. Turn the unit upside down.
3. Unlock the left battery lock.
4. Push battery lock on right outward to the release the battery.
5. Slide the battery out.
Now's the time for the strap. In lieu of that touch an unpainted metal part of the case and try to maintain contact. If you lose contact just touch again.
To remove the hard disk drive, then perform the following steps:
1. Remove the screws on the hard disk drive cover and carefully open it.
Cover is on the corner. ( 1" x 3")
2.
Pull out the hard disk drive using the plastic tab.
3. Remove the two screws on both sides of the hard disk drive shield.
That's all there is. Easy right? If you don't have an anti static bag wrap it in some bubble wrap to keep it safe.
Just reverse to put in new hard drive. If this helped you please rate a big 4 fix ya. Thanks. If you need more help just add a comment and I'll get right back to you.
Mar 18, 2008 | Computers & Internet
Toshiba Portege 3490CT Notebook Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
