Question about Samsung Refrigerators
Fan making very loud noise - Samsung Refrigerators
  • 1 more comment
  • geeple Aug 16, 2008
    Same here. The fan noise is on and off. When it is making noise, I can use my finger to stop the fan and the noise is gone. So it's definitely a noise from the fan. At the very beginning using oil spray takes away the noise but it seems to get worse and worse every month and now oiling it has no effect.
  • Anonymous Dec 19, 2008
    I have the same problem. I think when the freezer compressor kicks on then the looud noise last as long as the compressor takes to run and cool down the freezer section.
    I have not tkaen the back panel off but suspect its a fan making the loud noise as has been indicated here. Shuld would like to stop the irritating noise.
  • majf Apr 05, 2009
    Where do you spray the oil?
If it has not it will soon quit all together.
Take the panel at the bottom of the fridge side off, it is behind the drawers. Remove the drawers and shelves and all the phillips screws on the bottom part of the panel, not the top one that attaches to the light, just the bottom one. You will have to remove the two screws on the water line or squiggly white thing on the bottom to loosen up the panel above it. Unplug the two wires and Pull the panel out or lean it forward and take the 5 screws out to remove the fan and motor. Take the spring off the fan and pull it out of the shaft. Unscrew and remove the cover off the fan motor and replace the motor.
Some say you can oil the fan motor, but it will just collect dust ruin it. Mine made a noise for 3 or 4 days before it went out.
You can get the fan for the fridge side at:
It is about 24 bucks Fridge part # DA31-00002S
The one for the freezer is 35 bucks part #DA31-00020E
Posted on Feb 27, 2009
3 Suggested Answers
  • 398 Answers
SOURCE: Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Posted on Aug 03, 2009
  • 6784 Answers
SOURCE: loud fan noise
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Posted on Jun 02, 2010
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Dec 16, 2010 | HP (219426-001) Cooling Fan
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Fan makes loud noise when i start car
Firstly we need to know what model etc. Noisy fan if viscus could be the viscus itself - fan blade hitting something on the shroud / housing. First check & make sure the small bolts haven't shaken lose. Good luck
Jun 01, 2009 | 2001 Cadillac DeVille
Refrigerators Logo
723 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
