All in One Printer/Scanner/Copier will not respond to print command.
  • 446 Answers
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Posted on Jul 14, 2008
SOURCE: printer slow to respond to print command
I had this issue also. Found it to be a firewall issue.
Norton Internet Security, Vista Home Premium.
I ended up having to create a rule to allow inbound TCP from the laptop on port 135. Fixed it.
ps. Be careful setting up such a rule. Several worms make use of exploits on this port. I was very careful only to allow the laptop to loopback to itself.
Posted on Mar 09, 2008
Teis
  • 340 Answers
SOURCE: my printer,scanner and copier started
Hi again,
I sugest that you download a new driver from here: - you have to join them in order to get the driver, but its free. NOTE, you problem might bee that you have installed a Vista32 driver on a Vista64 computer, please be sure to download and install the right one.
regards /Teis
Posted on Dec 29, 2008
nadirsalim
  • 185 Answers
SOURCE: Just set up my Dell
Replace cable
Posted on Nov 13, 2010
SOURCE: I have a dell 1600n printer. Though it prints but
1) Remove the label completely from the scanner module by gently pulling it. The scan unlock switch automatically moves FORWARD to the unlock position.
2) NOTE: When you are moving the multi-function printer or do not intend to use it for a long period of time, move the switch BACKWARD to the lock position. To scan or copy a document, the switch must be unlocked.
Please see page 4 of the owners manual for more details. Here's a link in case you've lost yours:
http://support.dell.com/support/edocs/systems/1600n/en/OM/OM_EN_V01.pdf
I hope this response helps you out.
I wish you the very best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Posted on Jun 22, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark x4530 multifunction printer/copier/scanner. The
    There could be something blocking the scan communication - possibly a firewall. If you have a firewall enabled on your computer, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
    Posted on Jul 01, 2011
    I need to know what setting to put it on to print from my pc
    ensure that the printer driver is installed and it will print when you press the print command
    Jan 20, 2017 | HP Envy 4500 e-All-In-One Printer, Copier,...
    Printer says that "user intervention" but won't print
    Always check the connection cable. I had a printer that my computer couldn't detect, all caused by a bad lead.
    Feb 27, 2014 | HP Photosmart 5520 e-All-in-One -...
    After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
    Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
    Aug 29, 2012 | Canon imageRUNNER 400S Copier
    HP PSC 1210 PRINTER switches off when print command is given. Scanner and copier works fine. unintalled and reintalled several time .problem persists
    Shukla,
    It seems that the printer drivers are corrupted while the copier and scanner drivers are fine. Disconnect the device from the computer, uninstall the device from Control Panel->Add Remove Programs and reboot.
    Once rebooted, reinstall the device drivers from the CD that came with the device. Connect the device and allow Windows to autodetect it and load its drivers. Windows will tell you in the right bottom of the screen "The new hardware is installed and is ready for use".
    Start printing.
    Feb 10, 2011 | HP PSC 1210 All-In-One InkJet Printer
    Driver
    if the copier is not responding to print commands then you need to verify that the ip address listed in the print driver is the same as the one on the copier and that the copier's ip subnet and gateway are apropriate for your network...
    Dec 29, 2009 | Sharp AR-5320 Black and White Copier
    CX5500  Responds ok and tries to print but no print on paper
    this probably means that your nozzles are clogged. try to perform a cleaning cycle on your printer . like reseating the ink cartridges, head cleaning for about 4 to 5 times. then try again
    Sep 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Printing issue
    If command was with computer and you print mode of the printer, do stop by way of the removing the task sent on printer, from panel printers nominated printer afterwards remove problem, but if in mode of copying, push all reset buttom unset or removing the mode of the printer and translation on copying
    Sep 13, 2009 | Canon ImageRUNNER 330s Copier
    Laptop running vista will not print wirelessly
    check the cable connections, unplug replug the cable.......then turn it on
    Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Can't rip to 3200
    There are many reasons this could be occurring, first I would try pinging the copier to make sure you have connectivity
    Go to run command type cmd then in command prompt type
    ping xxx.xxx.xxx.xxx replace x's with copier IP address.
    If you get 4 replys then the copier is online and responding most likely the IP address in the print driver is wrong and needs to be changed.
    Ck IP address of print driver by right clicking printer go to properties the select ports tab. Find port and check address if it si incorrect then change to correct and hopefully it will correct your issue.
    I can give more help if this does not correct your issue.
    TankMurdock
    Apr 27, 2009 | Canon imageRUNNER C3200 Copier
    104 people viewed this question
    k24674
    jasbo
    jasbo
