Question about RCA P52926 52" Rear Projection Television
Convergence prob for d52w26 rear projection tv 52"
It is supposed to be auto convergence but the convergence is off and cant figure out a way to manually fix the prob??? can ayone help me please.
  • 1 more comment
  • imurdaddy02 Jul 14, 2008
    what exactly does IC stand for thx in advance.
  • drtyboy Sep 20, 2008
    the auto convergence is doe not help. the maneull option is no better. how do i fix this?
  • ty0023 Sep 21, 2008
    The convergence option is no longer coming out anymore and I need it...can u help me
I thought this Model dosn't have STK's?
Posted on Jul 17, 2008
  • 4,234 Answers
If the auto-convergence is not working then the convergence amp ICs are starting to fail. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Posted on Jul 14, 2008
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. listen...to the new maker, he can and will make you learn what manners are!!
Fixing rca D52w26 convergence problem can you try fixing with remote
No,must replace parts,These websites,have convergence kits for many DLP TVS.Tv Repair
World.com,Tv Repair kits.U know how to solder right?
Oct 23, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Colors not aligned
convergence circuit. prob. need tech
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26
very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Nov 19, 2008 | RCA P52926 52" Rear Projection Television
TV all blured and screen concaved on all sides
Look,followsteps and you wil repair this set. Disconnect main board ( fly back), take care about connectors. Under fly back you will see loose connections, resolder and that's it Am sure this is your solutions.You need do this soon, because fuse will be blown if keep blink picture, Thank you
Aug 08, 2008 | RCA P52926 52" Rear Projection Television
D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Jul 17, 2008 | RCA P52926 52" Rear Projection Television
The convergence is way off on my projection rca tv - i lost the manual but i have set it before in a menu but caint remember how to get to it Was watching a movie, tv shut off and powered back on by...
It should be in the options menu. If not often RCA will drop the option when the convergence ICs go out and often the set will shut down. Heres alink that should be able to help you get a manual and parts if needed. If they dont have your manual leave an email and they should be able to get one quckly usually within an hour or two.
http://servicemanuals.vstore.ca/
Apr 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
199 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
