Question about Philips 60P8341 60" Rear Projection Television
Too much red.
Our t.v. is kinda old and the color is very red. We've tried to adjust the color but that does not solve the problem. My husband has also tried the converge red/blue thing but that does not work either. Please help....
  • 3 more comments
  • tifferbee Jul 18, 2008
    i am also haveing trouble with the picture being red. I've tried adjusting the color also. any suggestions
  • josie_heyano Jul 30, 2008
    having the same problem !! love the t.v. just want to know what i ned to do to fix the color
  • yellar Aug 23, 2008
    Having trouble adjusting the color to a sharp picture on our TV....Too much red and green at times. Pictures looks unclear, not sharp colors.
  • Anonymous Oct 19, 2008
    i have a simular problem but my people are blury .Like we watching a movie in a night scene everything has a shadow
  • cherry7580 Nov 15, 2008
    I have a loss of all color except red and yellow. everything looks hazy/cloudy!!!
  • 85 Answers
It may be this common problem of older sets like yours the green and blue crt's may have a haze in the crt faces growing. I think if I remember right and this sounds like a lie but air has entered into the cooling fluid and bacteria or mold is growing and cover the crt faces look directly down into the crt's and see if there is a haze in them. If so you must change the cooling fluid this is a job not for the novice after changing the fliud and remounting the tubes a total reconvergence must be done and DO NOT SPILL any fliud onto ANY CIRCUIT board it will cause TROUBLE BEYOND BELIEF.
Posted on Sep 04, 2008
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
My tv the color is fading and now in one corner it is blurry and kinda red. Not sure how to describe this.
Ur convergence is dead.Have coner blurry red colors?U must know how to solders to solved this.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | Toshiba 46H84 46" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
