I have an old late 70s Peavey PA-400 powered mixer. It's a workhorse that suddenly started doing the following: As soon as you turn it on - both speakers hum pretty loudly, and the back of the PA begins to get really really hot. If you plug in a mic while the speakers are humming, PA overheats and auto-shuts off. After cooling, you can turn it back on. If I turn on the PA (without the speakers plugged in) and leave it on for a good 15 minutes, then plug in the speakers - no humming at all - no significat heat either. All seems to work well if I let the PA "warm up" for about 20 minutes! Something is definitely wrong.
  • moed33 Jul 14, 2008
    I'll have these things done and let you know. Thanks for the prompt reply!
  • 4,234 Answers
As these units get old, the solder joints can start to fail. Also, come of the components are getting tired. If you have no electronics experience, bring this to a servicer. I typically overhaul these units for about $100 plus parts. In most cases, the parts costis less than $20. These are solid units and you can probably get another 30 years out of it.
Part of the overhaul should be reseating all of the output transistors and replacing all of the heatsink compound as well as cleaning out all of the pots and switches.
Keep us posted.
Dan
Posted on Jul 14, 2008
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
Which output do I use on a Peavey Musician 400 to connect to a powered mixer?
On the front panel there will be a Line Out jack. That's the connection point. You may have to experiment with the gain control on your mixer to get the levels right.
May 28, 2016 | Peavey Music
Can i use a peavey PVi2 mic on my peavey renown 400?
No you need a preamp for the microphone found on audio mixers. You will not get good sound from it even if you do buy a mini mixer to provide a preamp for the mic. I would suggest a pa like the ones in this link. Most of them have built in mixers (with preamps) also.
Portable PA Systems Sweetwater com
Apr 12, 2016 | Peavey Audio Players & Recorders
Is there a way to hook a Mackie profx12 mixer to "this" Peavey PA?
We would need to know which Peavey PA you're asking about.
Feb 18, 2016 | Peavey Music
On my peavey xr1220, when I turn on the power switch the board does not power up. What could be the problem?
Probably a fuse ? I have been servicing a lot of Peavey equipment lately and they have some poor circuit designs, a lot of internal un accessible fuses, I might be able to get more info ?
Feb 22, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
Apr 27, 2011 | Peavey Kb 2 Keyboard Amplifier
PA Mixer
All mechanical switches such as sliders and pots will get noisy after time. They get mildew and tarnish on contacts. Get a can of WD-40 and spray all switches and pots inside. You can do this by inserting the straw nozzle into slider switch slot or pot space where wires and attach. Spray briefly (short burst), then work control to both extremes of travel.
Apr 21, 2008 | Audio Players & Recorders
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
180 people viewed this question
 Grubhead
Grubhead
