Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Replacing micro switch
How do I replace the micro switch which you recomended to fix the problem fo the grinder working but not sending cofee to the brew chamber.
  • 515 Answers
You have to take of the top, there are several screw to loosen.
  1. Take off the water tank and bean hopper
  2. Take out drip tray and dregbox
  3. loosen the two screw in front where the dregbox and driptray was ( one in each corner)
  4. Take of the plastic adjustment in the right corner (grinder adjustment)
  5. Loosen the screw in chassi where the water tank was, look inside where the beanhopper was to make sure there not are a screw, some models have one there. If there are one you will see that behind the grinder.
  6. Take off the plastic on your steam pipe.
  7. Take off the top.
  8. On the right side near the hole where you put pregrounded coffee, there will be a little microswitch.
I hope this will help you
Posted on Jul 15, 2008
  • dodelektrod Jul 09, 2011
    I checked the microswitch witk multimeter and is deems to be OK. Is it just simple on/off switch?
    My machine does not grind coffee. The grinder is OK but all I get is water in the cup.
Saeco grinder
Maybe the piece that direct cofee to brew group it is missing, so all cofee fall down.
Oct 04, 2013 | Coffee Makers & Espresso Machines
My makita angle grinder(9527NB) the on switch only works when it wants to. Turn it on dont work, bang it and it might work. Any suggestions
This is definitly a bad switch. You can contact Grainger or MSCDirect, and give them the model number and the make/ They should be able to send you out a new switch. These are pretty basic circuits and only take about 20min to replace.
Jun 08, 2011 | Makita Angle Grinder
The machine does not stop grinding - until all the beans are up & everything clogs up inside
The problem with a constant grinding and overflow of coffee is a micro switch in the doser box needs to be replaced. If you get the top off there is a solenoid in the center of the machine on top that has to be removed. There is a micro switch below and to the right that is bad or dirty and needs to be replaced. This micro switch turns off the grinder when the coffee pushes a arm against the micro switch. If the micro switch doesn't shut off the grinder the coffee overflows the box and falls into the brew unit. This is a very special micro switch that is only a 6 gram switch not like the others that look like it and are a 32 gram switch.
Feb 06, 2011 | Solis Master 5000 Espresso Machine
The grinder and the cover don't work i just got this for a gift about 6 months ago i cant believe it does not work. I try fixing but it still doesnt work the entire coffee box and the cover.
  • it can be too tight stringed at burrs
  • some stone or metal part with coffee went between burs
  • IF IT IS AUTOMATIC, it can be one of 2 micro-switches or main relay, in this case you have power but only to middle of way.
  1. Release the burrs, grind one amount coffee with bigger granulation than go back again carefully.
  2. Disassemble the upper burr holder and clean carefully, all coffee and remains put in one plate, inspect with magnet, hand and than put all that in water. (heavy parts fell down fast in water)
  3. Check the switches and relay:
  • Upper micro-switch has an plate and one box where it is( box might be full of coffee or the plate blocked and giving the signal of full doser every time)
  • Lower micro-switch should activate every 6th pull of doser(he is below in mechanism of doser)
  • Relay gets power from micro-switches when they command. even we switch on if the commandsof micro-switch says off than relay will not obey us.
Nov 25, 2010 | Coffee Makers & Espresso Machines
No cofee just beeping
Make sure every piece is in place. Usually the culprit behind the beeping is an out of place or damaged Grind Basket Lid - if it is in its proper place and you still get beeping even after unplugging the machine, then I would suspect that it is damaged - call Cuisinart for a replacement lid.
Jul 31, 2009 | Cuisinart Thermal DGB-600 Grinder
Grinder won't stop
You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
May 01, 2009 | Saeco Magic De Luxe Espresso Machine
Cofee cont.
You have to adjust the tension in the grinder.If too soft it will come up coffee beans empty.
Dec 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Vienna grinding issue
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
Nov 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
"COF. BEANS EMPTY" message
Here is a link for completely cleaning the grinder - this often fixes the problem:
Nov 12, 2007 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
145 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
