Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi projection 53" screen color off
The picture shows yellow shadows to the sides of the images and no longer has true color. There was a mention of bulbs needing to be replaced. Could this be what is causing it? We have a Hitachi HDTV Ultravision digital model #53UDX10B V1G005239. If it is a bulb is it possible to fix it ourselves, my husband is electronically knowledgable? If we can't fix it ourselves, what kind of cost are we looking at?
Thank you for your help
Sue Forbrook
ramb@windstream.net
  • 4,234 Answers
Since this is a CRT based projection set, there is no "lamp" involved. Does the picture look like 3-D? If so, the problem is likely to be a convergence problem. There should be 1 or 2 convergence ICs marked STK392-110 inside attached to a heatsink. If you can solder, try resoldering the pins on those ICs. If that fails to resolve the problem, replace them.
Keep us posted.
Dan
Posted on Jul 14, 2008
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My tv on the right of the screen is blurry,with green around the images.
Ur tv have a problems known as a convergence picture problems,it is dead.The tv have R,G,B colors lines mis alignments,tv have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead tv convergence board.The tv convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.After the tv convergence board is fixed,the tv convergence picture problems will be solved.The tv shop,will cost u like $300-350 for parts and labors.
Apr 26, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
My Hitachi television covers the image by blue color how i can solve this problem thank you
is the red color over the picture like coming out of the picture
or there is a color all over the screen?
thank you
Jose
Aug 13, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Shadowing
is this a color shadow like convergence problems or just dark?
Dec 26, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Projector Screen
does it look like this picture? you will have to scroll down a bit
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Yellow vertical bar on right edge of screen
Your set is starting to get a convergence problem and the only way to repair it is by changing the convergence IC's,(3)one for each color,the blue migh be showing more now but soon all 3 colors will be out of alignment and you will not be able to correct it with the custumer controls,is great that it has worked for so long without this problem,if you are familiar with tv service you have a place to check but if you are not too familiar be safe and call for help from a pro-servicer.Let Us know how it goes.
Oct 20, 2006 | Sony KP-53V45 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
136 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
