Question about Akai LCT3215/26 32 in. LCD Television
No green light
There is power to my t.v. because the red light is on but when i try to turn it on the green light does not come on therefore the t.v. does not come on.
  • 1 more comment
  • osvaldo7 Jan 14, 2009
    they say to me, is the power suply, but I can't find one new, maybe one universal, but, I need to know if my model of TV LCT32Z5TAP AKAI, the power suply is of one of two focus. ????
  • travispowell Feb 05, 2009
    My red light is on but my tv won't turn on and I unplugged everything
  • jsbcz Apr 02, 2009
    The red light is on but the TV wont turn on even after being unpluged. It's only 3 years old!!!
Power supply Capacitors, check and see if they are bulging, I replaced 3 and tv works great now
Posted on Jun 19, 2009
  • 31 Answers
Try these following steps to Fix your Problem.
- Unplug everything from your Television.
- Wait 60 seconds, and plug everything back in.
- If that does not work, try turning on your Television by the Remote. Or a Remote.
Hope this helps. - Evolution
Posted on Jul 14, 2008
4 Suggested Answers
  • 6 Answers
SOURCE: red light on display not green as usual no power
Hold down the "input" button and "volume -" button while the MAIN POWER BUTTON IS OFF. Then turn on the main power button while those are held down, the light on the tv & avc box will turn green. When it turns green, immediately let off the 2 buttons and press "volume +" button, then press the "Main Power" button. Next step is to repeat the process about 20-40 times & the TV WILL WORK!. I have read that this may have something to do with the energy star compliant commands that can changed through the serial port.
The above is from psxpirate25. Thanks!
I had to repeat the whole process a couple of times to get rid of the factory setup firmware mode. Do it 40 times, I would mess up the sequence a couple of times. Keep trying, it does work.
Posted on Aug 13, 2008
  • 8457 Answers
SOURCE: tv won't turn on. red power light is out
Power supply board is dead.Tries website Shopjimmy.com,Ebay.com to buy a refurbish power supply board for a replacement.
Posted on Mar 02, 2010
Testimonial: "Thank you for your help. This site is going into my favorites. Have a great night. "
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
The On/off button of my LG LCD does not turn on the tv and the red/green light of the power indicator doesn't light up, but when plugging in the power cable to the outlet the on/off button light is...
your TV has a power supply issue or a logic fault.
Don't try and fix this yourself as the power supplies in these TV sets are extremely dangerous !!
These TV's can only be fixed to board level which means this repair may get expensive.
My advice would be to take the TV to a professional or have them call to your home to check it out..
Jan 13, 2011 | LG Televison & Video
I am trying to hook up to my new comp. and new internet and the lights come on for the wireless, wired and router r green then the modem light is red, what am i doing wrong
There is nothing wrong with your modem. There are modems that when you turn it on, the wireless, dsl lights are green while the power light is red then after a few seconds, the green lights disappear and the red light will turn green. After sometime green light will come back on. This means your modem is restarting and doing a self check.
If the power light stays red, then you a have a problem with your modem.
Sep 10, 2010 | Computers & Internet
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
Will not stay on
Hi, this printer needs a repair, which unfortunately will cost more than the printer is worth. I agree with HP
Oct 28, 2007 | HP PhotoSmart 7660 InkJet Printer
It does not turn on, remains in stand by mode.
I cannot be COMPLETELY sure of this so be careful, but doesn't the PS3's board cater for both types of power supply and therefore a step down transformer is not needed? Check the labels on it just in case, but be wary I CANNOT be certain of this...
Aug 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
142 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
