Question about Olympus FE-230 Digital Camera
Fe 230 problem
Power turned on - lens will not engage. makes a winding
sound and stops. Was quoted $189 to fix - expensive
due to labor. Want to check before we buy new!
Any help would be appreciated.
Thank you. pam.jannece@gmail.com
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Try olympus repair for about $80.00
Posted on Sep 04, 2008
My FE-230 is only 2 years old and will not turn on/off properly
This sounds remarkedly like a camera that has been dropped. Even by someone else! The odd noise it the can[mera trying to set the lens up and failing. The black screen is because the lens has not travelled the distance etc. multiple problems !
it needs a complete overhaul and may well be cheaper to ditch it and get a new camera
Jul 30, 2009 | Olympus FE-230 Digital Camera
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
Camera tuns on extends lens 3 x then turns off
Sounds to me like it is not getting enough power to do anything else but turn on and then off again. When you are downloading pics. your camera is actually drawing a small amount of power from your USB port to perform the necessary download. Try checking your batterie(s). This MAY be the problem. Hope this helps.
Dec 27, 2008 | Olympus FE-230 Digital Camera
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
Fe 230 focus problem
the LCD may not light at the first due to low batteries too... but i feel there are some more problem... as the shot is also blur you can try cleaning your lens... the autofocus may not work due to dust also... try cleaning the lens of your camera
Oct 23, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
When I press the power button the lens just keeps going in and out. And when it does come on my pictures come out blurry. I have an Olympus FE 230.
I'm pretty sure you camera needs servicing. It sounds as though there is a problem with the focussing mechanism or motor, which would cause both of those symptoms. It's quite unlikely that you can fix this yourself. Hope it's still under guarantee!
Sep 05, 2008 | Cameras
I need help with my FE-230's focusing
in any case where the lens makes a grinding noise, something is in the channel and causing the lens to not extend all the way... you will need to send to a repair shop
Jul 31, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Logo
103 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
