Question about Whirlpool LEQ8000JQ Electric Dryer
Door Switch Need to replace broken door switch. Do I get to this part from top? How do I remove the top?
You do get it from the top. remove 2 screws by lint filter lid. there are 2 clips you can pop-up on the front corners of the top. it will raise and you will be able to un-wire it then. be sure to un-plug your dryer first.
Posted on Dec 26, 2008
How to Replace a Dryer Door Switch on a whirlpool
First, make sure the peg on the door that pushes the switch is in place and the two snap pegs that hold the door shut are not broken. If any of these are broken, replace them first and see if that solves your problem. If not, here's how to replace the door switch: Unplug the dryer. Pull out lint screen. Remove two screws revealed underneath. Slide a 1" putty knife between the top and cabinet at the top front corners on each side, jamb it in while tugging the top forward to release the clips, one at a time. Lift top and lean against wall. If it's a gas dryer, remove lower front panel and loosen two 5/16" hex head screws for top front panel. If electric, loosen same screws at bottom of front panel. Remove two 5/16" hex head screws holding front panel from inside near top. Carefully tilt front toward you, holding drum in place. Lift front panel slightly to disengage bottom screws and remove. Gently lower drum until it stops. Unplug two (sometimes three) wires to door switch on right side. Now the front panel is completely free. Remove two Phillips head screws holding door switch onto front panel. Reassembly is the reverse of disassembly. Make sure wiring to door switch is secured to cabinet so they don't drag on the drum, and are not pinched. Be careful realigning the drum into the door opening so felt seal is inside the front glide ring on the drum. After the front panel is in place, gently hand turn the drum to make sure it is turning properly and the belt in still hooked to the idler and motor pulleys. If the drum falls off the rear rollers, or the belt comes loose, you will have to correct it before putting the front panel back on, as you cannot reach them otherwise. Taking pictures during disassembly will help get it back together properly. It really is not as hard as it seems, you may even be able to replace the switch without removing the front panel. Also, if you have a three wire switch, write down where they go or snap a picture. If it's a two wire switch, it doesn't matter, it will work the same either way. Good luck.
Feb 18, 2014 | Whirlpool 358409 Washer/Dryer Screw &...
Whirlpool microwave won't open
Possible that the door switch is broken or jammed,. You need to remove the top cover, open the panel and remove the door and switch , check for broken plastic or lock, If so use glue to stick and reset.
Jan 24, 2013 | Microwave Ovens
When I close the door on the rvm1325bwoo2 microwave oven the light and fan continue to work. I can push the top of the door and they go off. Do I need to replace the interlock switch? The latch is not...
It may be a loose or misaligned top door switch or that switch's mount, or possibly a bent or misaligned door.
See our file on door switches.
It would be useful to remove the controller and then observe how the upper door latch head (hooklike device) activates the top door switch when you open and close the door.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Sep 09, 2011 | Hotpoint RVM1435 Microwave Oven
What is an error code of DL?
F/dL error - Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
Good luck.
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Dryer does not stop when you open door
The door switch is sticking. Door switch is around the door opening and is located where the door would push it in when the door is closed. It may just need cleaning or putting back in its rightful place or it may be broken and need replacing.
More info, let me know.
Charlie
Mar 30, 2011 | Whirlpool LER8648L Electric Dryer
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool electric dryer will not start Model # LER6644DQO
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 30, 2009 | Dryers
Dryer
#1 Unplug the dryer
#2 Use a putty blade under the corners of the Console and flip it back
#3 Remove 3 screws along back of top that were under the console (Might just be 2)
#4 Slide the top forward and remove
You will now have full access to the switch. Disconnect the harness and replace the switch.
#5 Reverse the above proceedure to replace the top
Good Luck,
Eric
Jun 08, 2009 | Kenmore 64902 Electric Dryer
Will get hot but drum will not go around
If the door switch is in good condition and, it is functioning, replace the electronic control board assembly.
Apr 22, 2009 | Whirlpool GEW9200L Electric Dryer
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
Whirlpool LEQ8000JQ Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
