FixYa.com
Tags:
Dynasty DGRSC 30 Gas Kitchen Range
Dynasty model dgr-336b mfg.1993 converted to...
posted by samskathyg on Jul 14, 2008
oven takes a long time to ignite 10-15 minutes
once on there is a loud woshing sound sounds like a jet
as the gas comes on and off
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
pull up the floor of your oven and look at the burner, have any of the small gas holes rusted out in to bigger holes? Sounds like it is possible that most of the gas is now coming out a 'burned out' hole rather than the small neat row of normal holes. Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
need to dismantle an AGA.
need to dismantle an AGA. where... Answer This...
Kitchen Ranges
What is the self cleaning
What is the self cleaning code... Answer This...
Kitchen Ranges
oven stop working when code
oven stop working when code f1... Answer This...
Dynasty range, oven does not...
only the left side of the two... Answer This...
Oven failing to light
The oven igniter is not coming... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
