Question about Batesias BT-1501 (Silver) 15 in. Flat Panel LCD Monitor
Over Range After the Windows loads,the monitor displays Signal Over Range. How do I fix?
    Genius:
  • 1,689 Answers
The display card resolution is set too high for the handling of the monitor, or the system board in the monitor is faulty.
Jerry G.
Posted on Jul 15, 2008
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Signal over range.
Could be a driver issue with your monitor. Safe mode bypasses them with working defaults.
Aug 31, 2017 | Acer X193W LCD Monitor
Monitor says: "Out of range"
This means that a video signal has been detected but it is beyond the range for display. As an example, if the monitor can only display 1024x768 and you send it a signal at 1280x1024, you will get that message. Try to downsize the display settings on your computer system until the monotor works.
Dan
Nov 06, 2009 | BenQ FP767 17" LCD Monitor
Signal out of range
If your PC is working with a different monitor then your monitor is going bad.
Mar 28, 2009 | Computers & Internet
Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Feb 02, 2008 | Balance CM2017 17" Monitor
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Input Signal Out Of Range
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Batesias BT-1501 (Silver) 15 in. Flat Panel LCD Monitor Logo
129 people viewed this question
Top Batesias Computers & Internet Experts
David Payne
David Payne
Are you a Batesias Computer and Internet Expert? Answer questions, earn points and help others
