Question about Systemax Computers & Internet
I press the switch to turn on the computer and the lights flash and nothing happens. I cannot turn the computer on.
  • 781 Answers
Try this unplug power cord for 1/2 minutes reconnect try this might work you may have had a power surge
Posted on Jul 14, 2008
When turning on my technika it has a red flashing light but nothing else happens when I press the remote that came with it.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 01, 2015 | Televison & Video
The TV will not turn on. When the switch at the lower left corner is pressed the light in the switch flashs green for about 4 seconds as the TV seems to go through a start up procedure. Then the light...
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
Oct 10, 2010 | Panasonic TH-46PZ800U Plasma TV
My brake lights are not working, My light turn on, my blinkers work, emergency lights flash, but nothing happens when I press on my brakes?
Sounds like a brake pedal switch fault take the switch of the brake pedal and remove connection , bridge the two wires and check if the b lights are working if so change the switch. If not check the bulbs
Oct 04, 2010 | 1995 Honda Accord
Installed the prestige remote start(aps687n) on my 95 jeep grand cherokee but when i try to remote start my parking lights just flash 7 times and nothing happens. Any ideas???
Yes, the seven flashes mean that the tachometer setting has not been programmed. If you hooked up a tach wire (green with orange stripe) to an uncommon coil or injector wire, then you have to program tach: turn ignition on, press and release programming switch three (3) times. The parking lights will flash once to confirm. Turn ignition off. Press and hold programming switch. While holding the programming switch, start the vehicle. The parking lights will flash to confirm that the remote starter is getting a tach signal from the vehicle. Continue to hold the switch for approximately 15 seconds.The parking lights will continue to flash while holding the switch. Release the programming switch. The parking lights will come on solid for one second, then go off. The tach is not programmed. Turn ignition off. Test system.
Sep 19, 2010 | Prestige Remote Start
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Screen frozen, control not working with computer.
make sure batteries are ok, sounds like it is not in sync.
thx
Aug 01, 2009 | Nintendo Wii Console
Wii turns on, says press A, Press A,Nothing happens
if the 4 lights flash on the bottom of the wiimote you need to sync the controller to thhe wii
Feb 03, 2009 | Nintendo Wii Console
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Laptop notebook
Your battery may be drained .
Turn off remove ur battery and switch it to ac power and start again .
If its ok insert battery and charge it.
Good Luck
Dont for get to vote. Merry Christmas
Dec 06, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
53 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
