Question about HP OfficeJet 7310 All-In-One InkJet Printer
Colored Vertical Lines when ADF Scanning
When I scan using the ADF & HP Director I have recently started getting 3-5 magenta, yellow and / or cyan vertical lines about 2 inches in from the left margin. I have cleaned everything, however the colors lead me to believe it is not a cleaning issue. This does not happen when I scan from the glass and also doesn't happen when I copy from the ADF. Does anyone have any ideas for me?
  • 446 Answers
The scanner system using ADF is not the same as in using from the platen glass, (CIS usually called contact image sensor) reads your document and sends the info to be printed, chances are your CIS assembly could be dirty and have some dirt on its surface, try opening this area on the top of ADF and clean with a moistened cloth, especially the affeced left margin, it should work!
Posted on Jul 14, 2008
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Epson l200 ink pad error
epson L200 ink pads error Epson L200 is an All-In-One printer, All-In-One printer is a printer unit has multiple function as Scanning, Photocopying, and printing. Epson L200 comes with 6 ink bottle consist of 3 Black Ink, and colored ink, 1 bottle for Cyan, 1 bottle for Magenta, and 1 bottle for Yellow Colors pls check epson L200 ink pads error reset http://www.2012teamtech.com/epson-l200-ink-pads-error
Dec 25, 2013 | Epson L200 Original Continuous Ink Tank...
INK PADS FULL
get the ink reset utility with key
May 02, 2013 | Epson L200 Original Continuous Ink Tank...
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
Vertical lines on output
If the are yellow replace the yellow cart Cyan replace the cyan Magenta replace the magenta. Thank you, Steven 808-520-3003
Jul 26, 2010 | HP Color LaserJet 2600n Printer
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Vertical lines when scanning using automatic document feeder...Glass is clean
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
Nov 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Dell 1600n ADF Problem
You have either a piece of dust or a scratch on the scanning glass. This will show up as a line because the paper is pulled across the point.
Nov 12, 2007 | Dell 1600n All-In-One Laser Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
255 people viewed this question
Seeker5211
Seeker5211
