Hi on my hp psc2110 all in one ,I have just replaced an old black ink cartridge with a new one .I have tried several times to print and scan.But the error message :Remove and check right cartridge:still appears .Please can you help thanks.
  • williamfcoad Sep 02, 2008
    I have the exact same problem the printer will work at all- how do you fix this?
    Problem Solver:
  • 5 Answers
Most likely some problem with the cartridge itself.
if you are using "aftermarket" cartridges, that is usually why the printer doesnt full recognise it...if using a real hp cartridge, there might be a problem with the little circuit board (that is under the tape strip when new)...try returning it to the store where you bought it and asking for a replacement.
Posted on Jan 03, 2009
Hi friend, I refilled the black ink into the
i've quite come across this kind of problems many times. Simply replace your cartridge with new ones or try that old one to dip its head in the hot water for sometime.
Dec 09, 2009 | HP Officejet 6500 Wireless All-in-One...
Poor print quality and I don't think it's the ink cartridge
Dec 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
"E", doesnt print scan or copy
Ink has dried inside the printer.
Assuming the printhead is seperate from the cartridge, i would inject JR Inkjet flush into the old cartridge and put it back into the printer. Leave it to stand for an hour or two, then run several cleaning cycles.
Once the ink comes through (if it does) replace your new cartridge and clean again until the print quality is restored.
If this does not work. Then i expect a new printhead is required. (i would try the first suggestion repeatedly).
Ink cartridges should be replaced immediately if possible. and even if u need our technician support contact us at
Jun 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
313 people viewed this question
