Question about Microwave Ovens
WHIRLPOOL Gold - GH7155XHS-1
I Can turn the turntable manually. This microwave does contain an on/off switch for the turntable but the turntable does not turn automatically when the on switch is pressed.
  • Microwave Ovens Master
  • 9,098 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
  • William Miller
    William Miller Jul 19, 2008
    "Thanks for trying"?
    I gave you virtually all the information you need to fix it.
    Do you just not like the answer?
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
What turntable motor do I need for a whirlpool MW B10 W microwave?
Refer your inquiry directly to Whirlpool or an appliance parts supplier.
Jun 11, 2014 | Whirlpool GH7155XHS Microwave Oven
My husband found the fuse and checked it and it was still good
If it has a turntable inside does that work when the unit is turned on or not?
Nov 08, 2012 | Whirlpool GH7155XHS Microwave Oven
Turn table does not turn
unplugg it for over a hour then try again, if that does nothing you will need to replace the turntable motor.
Just so you know that model has a stir so it does not need to turn to heat just right
Oct 31, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
DOOR ISSUES?
not sure how technically inclined you are and whether you like taking things apart. it's either the door has become slightly warped or the hinge is abit loose or the safety switch needs adjustment. if it's the switch i'm not sure that can be adjusted from outside the machine.
Sep 02, 2009 | Whirlpool GH7155XHS Microwave Oven
PCB repair
Yes we can.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
Before you power it back up after the repair, you should double-check the wiring of the switches against the "mini-manual".
It's located behind the grille or below the circuit board.
If you don't find yours, you can download it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 03, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool Gold Microwave Mod#GH7155XHS-1
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
106 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
