How do you connect the scart cables to a dvd - Televison & Video
    Problem Solver:
  • 6 Answers
Very simple method, On the back of the dvd you may find 2 scart connetions. Connet the scart lead to the one marked TV and the other end to the tv.
switch on you dvd and it should automatically change to the AV channel and thats it!!!!
Posted on Jul 14, 2008
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Connecting a dvd player to a logik tv
see the diagram attached: God bless you
Jul 21, 2012 | Televison & Video
What cable do i need to connect philips dvp3520/05 to hd tv
The DVD player only has a SCART out and unless you have an European model TV it won't have a SCART input. So you have to buy a SCART to RCA cable and connect the RCA end to the TV's AV input ( Yellow to Video and Red/White to audio input )
Mar 17, 2011 | Philips DVDR3380/05 DVD Recorder
I want to hook up my dvd to the tv, but I dont know what plugs into what
check for any HDMI Input on Tv, and also on DVD as Output , or connect a SCART CABLE from DVD SCART(TV OUT) to TV SCART(AV1 or 2), note:
Use a High quality cables, better IMAGE/AUDIO is achived.
Jan 10, 2010 | Televison & Video
Proscan PS8682P dvd player. It has been over a
so you have two problems: how to connect to (ex: tv),so for this. the cable box has a scart port? if so use a scart/rca adapter available on the market, use on VCR out (Cable Box) and select IN the adapter to IN/OUT switch. and connect to dvd player. The other Scart Port labeled TV connect to TV set with a scart cable. Now u can see tv, and switch automatic to dvd if DVD is on.
The Bad Disc error is a Laser DVD lens defective, needs to be replaced, send to repair.
Dec 28, 2009 | Proscan PS8682P
How do I connect a JVC DVD video player model XV-S302SL to a cable box and a TV
There are several ways in which you can do this.
The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
Hope this Helped Clarify things for you.
If this has then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 14, 2009 | Televison & Video
How do you connect a toshiba dvd to a tlc plasma tv
First of all unplug tv and tosh dvd.
1.connect the antenna(digital aerial) to the ATENNA IN jack of the dvd.
2.connect the ANTENNA OUT jack of the dvd to the Aerial jack of your TV.Using a RF cable(usually supplied if new)
3.Connect AV1(TV) scart socket of the dvd to the scart socket of your tv.Using a scart cable.
Then you are ready to start and program the channels.
Oct 10, 2009 | Televison & Video
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
How to connect two vcr via scart cable over old tv
what you mean old tv ? with not scart conection?if yes,conect first vrc to second vcr via scart and second vcr via rf cable to tv if no scart socet on tv or via scart if tv have scart conection.
Aug 14, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
