Question about Garmin Nuvi 660 GPS Receiver
Garmin 660 will not pick up satellites
  • 446 Answers
Go to a clear sky with a clear reception, or try reseting your GPS.
if you just happen to enter new information while driving this would sometimes freeze your GPS as a protection whilst driving
Posted on Jul 14, 2008
My garmin nuvi 660 stopped receiving satellite signal. Reset has no effect. Everything else seem to work.
Power your unit on outside, make sure you have a clear view of the sky. If your unit is working properly, then it should pick up the satellites. If so, then you can put the unit back in your vehicle and make sure it is positioned to maintain a satellite lock. If you cannot acquire satellites outside, then the unit is defective.
Jan 01, 2017 | Garmin GPS
Garmin 660 reads as acquiring satellite and stays stuck in this screen. Reset default settings, moved around outside to get the signal.
satellite receivers seem to be doing this on cloudy days also bad line of sight to the sky. say the unit is being blocked from seeing out the window properly or is in to far from the windshield it will not have a direct line of sight with the sky. thus no signal acquisition.
these units rely on signal triangulation to track your Xiamath location it takes 4 satellites to give your exact or near exact coordinates consider that your line of sight is not the problem then is say theirs a issue with eh unit and it may be defective. but try holding it outside the car a second like out the window and see if it picks Anny satellite up. if so then line of sight is probably the issue here. good luck and thanks for using fixya service.
Sep 20, 2009 | Garmin Nuvi 660 GPS Receiver
Lost satellite connection
Please see this link for more information on this problem. Too much info to cover here:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Aug 05, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 cannot acquire satellites
Hi I had this problem and its an antenna fault, give garmin a call and see if yours is still under warranty, if it is they will tell you to take it back to the retailor who will call garmin for a RA Number and they will replace it there and then. If your warranty has run out then call garmin to ask about repairs
Best Of Luck
Jul 19, 2009 | Garmin Nuvi 660 GPS Receiver
Poor satellite signal on my garmin 660?
you should update the unit software to the last ver
Jul 07, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin c550 phone book problem
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
just model number is different but the system is same
hope this helps
Nov 25, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 660
If you start it up and are located in the place where the pin code was set, then the unit should unlock once it acquires sufficient satellite signals.
Sep 05, 2008 | Garmin Nuvi 660 GPS Receiver
Won't pick up satellites
It fixed my garmin Nuvi 660:
With the unit off press firmly on the upper left hand corner of the screen with the tip of your finger.
2. Press the power button. When you see the screen light up let go of the power button but continue to press on the upper left hand corner of the screen until you receive the message "Do You Really Want to Start Up In Maintenance Mode?"
3. Say Yes and then select the third Option "Clear All User Data" and then say Yes.
4. The unit will then start up and ask you to set some preferences.
5. Once the unit is on the Main Menu please sit it in a safe place outside with a clear view of the sky for about 10 minutes and let it lock on to the satellites.
Jul 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
239 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
