Question about Apple iPhone Smartphone
Intermittently my iPhone does not ring and incoming calls get forwarded.
I'm using a Jail broken Iphone (1.1.4 firmware version), and intermittently my iPhone does not ring when there is an incoming call. How I would know I missed the call is, when I press the home button I see the message on screen saying "Incoming Call Forwarded".
I would have to re-start the phone for it to start ringing again.
Incoming call not come in myiphone want solution
Posted on Oct 14, 2009
Through the iPhone to dustbin and buy a normal phone. It works better than this iphone. This happens to a lot of people.
Posted on Sep 15, 2008
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Error 1015 iphone 3g ,stuck in recovery mode
The easiest way to fix iPhone recovery mode screen is to use the free tool called ReiBoot. i used it before and it worked perfectly for me. What's more, it is very easy. No need to connect to iTunes and hold any button on iPhone. You can try it if needed.
Tenorshare ReiBoot
Sep 11, 2014 | Apple iPhone 3G
How to unlock iphone 3g version 3.1.3
As on date 3.1.3 firmware with baseband 05.12.01 can only be jail broken (using spiritjb.com). It cannot be unlocked to be used with other GSM carriers.
Apr 09, 2010 | Apple iPhone 3G Black Smartphone
Iphone won't recognize sim
Your phone must be jail broken and unlocked to use non AT&T sim card. Be sure you have correctly installed redsn0w and ultrasn0w unlocker. If you have recently updated your phone that will undo your jailbreak and unlock. You will need to reapply them for the version of your iPhone OS if they are available.
Aug 03, 2009 | Apple iPhone Smartphone
Phone won't ring in sleep mode
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
Jan 08, 2009 | Apple iPhone 3G Black Smartphone
IPhone dialing keypad problem, 2g , 2.2 firmware
I just found the answer on another website. Go onto installer or cydia and uninstall Mobile Enhancer. Restart your phone and it will work. Thank god!
Nov 28, 2008 | Apple iPhone Smartphone
Screen becomes blank when call comes
try jail brek thru ziphone and try restorg again for d touch scren 2 work
Nov 13, 2008 | Apple iPhone Smartphone
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
Jail broken iPhone can't make calls
i had something similar where my iphone just freezes and goes back to home 3 seconds after i go to the phone part of the iphone. I just went to settings>RiP Dev (something I downloaded after jailbreaking)>RiP Dev Products > Kate and there Look for a checked application called facelift. I unchecked it and my calling worked again. It was cause Facelift is not compadable with Winter Board (another app dled from installer) If this doesnt solve the problem then... sorry :x
May 04, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
1,145 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
