Back to:
Tags:
GE Profile Harmony DPGT750EC Electric Dryer
The dryer not heating up (by 2 users)
posted by cliaw on Jul 14, 2008
How can i fix the problem? the book you mentioned, does it have a solution? please help
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by baiello123, posted on Jul 17, 2008
Heating at first but then not.
Best Solution
posted on Jul 27, 2008
Thanks for Trying (70)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 402 votes
All dryers take approx.60-75 minutes for a Large load to completely dry.If you have checked your vent hose and made sure there is FULL AIR BLOWING out it than you would then check for either a bad high limit or mixture thermostat or faulty Split Coils.If you have zero heat you go to Thermal Fuse & Igniter. Please Rate This !!
Thank You & If there is any question you have Fixya will be here to give you the Answer!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on The dryer not heating up:
I don't want to Accept this solution
Can you Help with these Dryers problems?
Brand new dryer (10 days old). Worked fine until...
i have a ge profile harmony and it will dry for a week and...
I have a GE DPGT750EC1WW dryer. Tub turns fine, bit there...
My harmony dryer is un assembled. it will humm motor but...
I have the GE profile dryer DPGT750EC1PL it has stopped...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
