Question about Microwave Ovens
Hitachi convection 800 microwave no power - Microwave Ovens
  • Microwave Ovens Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
I just bought the microwave/ convection oven 800 series. Do I have to take the rack out when I use the microwave, and the turntable out when I use the convection oven?
No you do not have to remove anything. The rack is made to be in there. If you still are not sure look in the owners manual or call the place where you bought it. I have a combo oven/ microwave also and can use one or the other or both at the same time
Mar 01, 2015 | Bosch Benchmark Series HMC80251UC 30"...
Miele H 4080 Microwave mica diffuser plate
http://www.amazon.com/Amico-Microwave-Repairing-Plates-Sheets/dp/B00880DAB0
Oct 19, 2013 | Miele M613GSS 800 Watts Convection /...
Why does my microwave oven keep cutting out and clock needs resetting before it can be used again
Check the screws in the mains plug and the wall socket. If there is no problem there, check the fuse holder in the microwave itself for bad contacts.
Hope this helps.
Nov 04, 2010 | Neff H7881N2GB 800 Watts Convection /...
I have lost the manual, where can I get a new one please
Hello :
Check this link for manual please :
R-654 800 Watts Convection Microwave Oven manual .
It could be that the link I've provided empty . If so , please look for the manual there , i found it , but due some techincal issus the link could come to you empty [not useful ] .
good luck .
rate please !
Mar 21, 2010 | Sharp R-654 Convection/Microwave Oven
Working perfectly until I put the 2nd mince pie into machine. No power so I changed fuse on plug but nothing. Has it just worn out? David
You may have an inline fuse inside microwave. You need to remove the casing of the microwave to see if there is another fuse inside (usually near the magnatron) If there is a fuse there then there's your problem, if not, then there is no use in trying to repair since the magnatron unit has possibly gone bad.
Hope this helped you
Dave
Jan 29, 2010 | Sharp R-206 800 Watts Convection /...
My kenomore Microwave has pwer and has stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
0ut
Dec 26, 2008 | Kenmore 63793 Convection / Microwave Oven
Microwave abrupting stopped functioning
It may be overheating due to a failed convection fan, or one of the internal thermostats may be failing.
Convection models can be very involved to disassemble.
Being an LG / Goldstar, I can't point you to any online service data.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 11, 2008 | Microwave Ovens
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
My microwave shuts off after a few mins. of use
There seems to be a rash of these units failing in this way due to bad magnetrons. The magnetrons normally have a warranty that runs for a few years. In some models, they have a whole kit they replace, consisting of a new magnetron, stirrer, and high-voltage rectifier diode. I would call GE Customer Relations with your model and serial numbers to see if yours is affected. They're at 1-800-386-1215 (8-6 ET). I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 28, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
109 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
