Check to see if the right wattage bulbs are fitted. If the wattage is low, then the bulbs will not flash. Harleys require 21 watt bulbs for the flashers.
does it make noise when turning ? when installing new power steering pump with both front tires in air on jack stands or jacks start and fully steer right fully steer left repeat a couple times and shut off now pump is bled place on ground and test....by turning take a drive....
First of all try hold the right trigger if a recovery mode pops up go to usb mode and hit X. hook it up to ur computer and then run psp deluxe and tell it what drive ur psp is and then do what they tell you to do and set dcmenu as left trigger and start it and then trun off turn back while u hold left trigger! if a menu comes up with 4.01 m33 do that!\\
I had a similar problem, and found that it was due to not having the vehicle speed sensor hooked up to the unit. Once I did that, it started to work again.
