Question about Ovens
Belling xou499ss How do I clean the roof of this oven? There are heating elements masking the roof.
  • 18 Answers
SOURCE: Belling Synergie fan oven.
the elemet has burned out round the fan
Posted on Jul 12, 2007
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
  • 1531 Answers
SOURCE: My oven says that it's on (heating up or cleaning,
no i do not think your elements are bad.it soundsd more like the main control board has malfunctioned.
Posted on Sep 16, 2009
Testimonial: "Thanks, I'll take a look."
barkencoa
  • 3463 Answers
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Thankyou.
Posted on Feb 02, 2010
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
All the temperatures have rubbed off on my belling oven,it's guesswork at mo,help please.
you fan is working in oven and there is no heat that means need new heating element check heating element that is located on back wall of oven covered with metal plate belling elements can be found on website click link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
Nov 17, 2012 | Ovens
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
My belling xou174 oven is not heating up fully
Hi
have checked to see if the element is open circuit with a muiltmeter? because if you are getting power to the element but no heat the the fault will be the element hope this helps you
regards dan
Jan 26, 2009 | Belling XOU174 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
