Question about Kicker Car Audio & Video
I have a kicker amp the zx 350.2 amp and the proble i am having is the gain knob is not making a good connection it cause bas distortion or not playing at all the part number to the part where the gain knob is attached is kicker 083KX2CHP version 2.1 i woupld like to replace this part but i have no clue where to get one
  • 96 Answers
SOURCE: price check
you would need the L7 dual 4 ohm subs they cost $200 each and the zx1000 amp runs $400 each.
However, the zx1000.1 amps will barely push them (L5 1200 watt would be a better choice on that amp) so the total cost shipped with authorized kicker warranty for 1 year would be $1200.00
I do however have 1 new in box single 06S12L7 dual 4 ohm in stock for $150 shipped its under full manufacturer warranty as well. the amps you need to push the rated power for L7 subs is the zx1500.1 and they are $600 each all of these prices are nearly 1/2 of retail that kicker requires its dealers to sell at, however i am a distributor so I can sell at w/e price I want :)
I can get you into a much better sub and amp combo for less but it isn't kicker brand. I went from 4 L7 12's running zx1500.1 to each sub for a total of 6000 watts RMS and hit 151 db and switched to Hifonics subs and amps and hit 157.3 with only 2 12 inch square brutus subs and 1 2000 watt RMS class d brutus amp. Hifonics will even warranty a blown or burned sub but kicker will not because they know they have voice coil heat issues with them. I have been using the same 2 subs and single amp for 9 months now in serious street beat comps and have never had an issue other than breaking car glass, however with the kicker sub amp combo in 7 months i went through 5 subs and 2 amps and never broke a window.
I can get you the brutus amp for $350 shipped and the subs for $260 a pair shipped or $600 for the combo shipped which is 1/2 the cost of the kicker at twice the quality and sound output. Hifonics is the only company to ever win more than 150 sanctioned events in a single season and they hold the record with over 210 wins in a season
let me know what you think on the price and I will do what I can to help out.
Posted on Sep 15, 2008
  • 10 Answers
SOURCE: i have a kicker l7 12 and a kicker 500.2 amp and
its problably grounding out check your wiring
Posted on Sep 29, 2009
  • 29 Answers
SOURCE: i wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Posted on Oct 13, 2009
  • 218 Answers
SOURCE: i have a pair of
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Posted on Mar 20, 2011
  • 492 Answers
SOURCE: How do I tune my
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Posted on Aug 20, 2011
Rear left channel makes my speaker pop cuts in and ou at certain settings
Swap left and right speakers. Does it stay with the speakers if so you have a blown or damaged speaker. If not then swap input cables only. If it stayed with the speaker you now know the amp has a bad channel and needs repair. If it swapped again you either have a bad cable or issue with your source unit.
Jul 26, 2016 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
@aol.comI have a kicker zx 1500.1 amplifier and a 15 inch L7 2ohms. Is the amp too much for it?
the amplifier is never to much for the sub. If the gain on the amp is turned up to much then that will pop the sub.
Jul 30, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
Mar 20, 2011 | Kicker Car Audio & Video
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
I have 2 kenwood 3011 400 watts rms and 12oowatts peak power each 1 is blown and wonderin about upgrading 2 the Hifonic Olympus OLM1612 would this be a good upgrade even thought i only a 400 watt kicker...
yea for sure thats a good upgrade. You shouldnt havebeen able to blow the kenwoods with 400 watts though-meaning that they probably blew from distortion which causes heat(fast) Check your gain on the amp start it out at 1/4 gain and turn up your deck to the point where you can hear distortion from your mids and highs or to the maximum level that you listen to your music at. If you're jamming out at a level that is causing distortion then you will be sending a distorted signal to the amp as well. The amp then amplifies the distorted signal through the subs which overheat and blow. So find the distortion spot and then turn it down just a little bit till it clears up your sound-then adjust your gain on the amp up slowly until you cant hear it getting any louder. Once you have done that you have reached the limit of CLEAN power that you are going to get.Thats where you want to keep it. Watch the bass boost too if you have the bass up on the deck and then crank up the bass boost on the amp it really f's up the signal too. Good luck
Jan 31, 2010 | Hifonics OLYMPUS OLM1612 Car Subwoofer
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
How do i make my two l5 10 subs sounds with clear
Try these:
Make sure the gain isn't set too high. That's a very common cause of distortion. You'll never want it set above 3/4 of the way to high. It will be a small dial on your amp marked "gain".
See if your receiver has a built in crossover on the channel your amp is hooked up to and set it so the cut off is at 400hz if possible. Meaning that the receiver will only send frequencies of 450hz or lower to your amp
Look on the amp for a built in crossover to the channel your amp is hooked to and set it to 450hz.
Make sure the cable that connects your amp to your stereo isn't running near any power cables of any kind because electricity running through a power cable can be picked up and then the sound it makes will be amplified, sent to your subs and cause distortion.
Make sure your amplifier isn't grounded to
your battery as this can cause what's called ground loop noise...also distortion.
Ground your amp as far away from the amp itself and your subs as the manufacturer safely recommends.
If none of those help then i'll try again :)
Apr 06, 2009 | Kicker Solo-Baric L5 Car Subwoofer
provided that the memphis studio series is still 1 ohm stable you would wire each coil of each speaker like this : posive to positive negative to negetive on the speaker using 2 jumper wires then run 1 coil from each subs positive and negative the input on the amp that amp would see a 1 ohm load from both speakers as each speaker would become a 2 ohm load. from experience, memphis does not make an amplifier that is brutal enough on power for L7 15" solos, i have the st 1600 d amp running only 2 dual 4 ohm 10 L5's and it is barely enough power for them. For less money than your 2 subs cost retail I can get you brand new matching 2000 watt true competition rated and proven 1 ohm power and 2 subs that would physically fit in your current box, i would however recommend a very very large box for 2 15" squares. you can email me at , my advice and system designs are always free even if you do not buy thru me. I am usually 1/3 to 1/2 what retail is with full warranties and i can drop ship anywhere in the U.S.A.
Jun 25, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
49 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
