Question about Kenmore Washing Machines
I need a price for a belt for the water pump to pump out and spin out the water. I have a Kenmore Washing Machine/Spin Dryer. On the plate on the back is C260-21501 Serial# 01 042 20125 Patented in Canada 1971 . You can email me at alenater@ntl.sympatico.ca
  • alenater Jul 15, 2008
    You were great and fast to getting back to me with the information I needed . But I have have the problem solved for now . If it happens again I know where to go for now on Thank you so much for your time .
    Sniper:
  • 67 Answers
Http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3480&PPStack=1 this is a good link for parts for your machine ,I picked the page with your belt.If this helps please give me a fix ya vote
Posted on Jul 14, 2008
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Kenmore oasis he....willnot spin flashes f
The most common reason for the washing machine not to spin or sometimes not to drain is the punp.If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks for contacting fixya.com
Nov 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
In spin cycle the basket wont spin causing clothes to stay soaking wet
hello. thank you for selecting fixya! If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Regards, Joe
Nov 07, 2009 | Kenmore 22422 Top Load Washer
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My dryer has to be restarted numerous times before my clothes are full dry. do i need to but anothe rdryer, and my washer machine doesn't seem to want to fully spin, majority of my clothes still are wet...
Hello. your machines each have problems that are complicated and expensive to repair. I would recommend replacing them both because of the cost of repairing the old ones and, the fact the the new ones are much less expensive to operate. They use less electricity and less water.
Jun 20, 2009 | Kenmore 94702 Front Load Stacked Washer /...
My Kenmore washing machine, top load, will not
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
May 06, 2009 | Kenmore Washing Machines
Washing machine 26652 kenmore
Feb 20, 2009 | Kenmore 26652
Washing machine
check out the motor of the machine. It doesn't spin If your washer won't spin, check these:
Dec 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore frontload washing machine doesn't spin
Nov 07, 2008 | Washing Machines
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Ron Lankford
Archaeology
Archaeology
2mikecurtis
