Question about Kodak EasyShare M853 Digital Camera
Flash My Camera Flash is not working. I don't know if the light can go bad, but the camera is pretty new.
  • laurieann226 Dec 07, 2008
    Flash should be working because I set it to work, but when the picture is taken, it does not go off
  • mstripplem Feb 02, 2009
    I have the same problem- flash is turned on but doesn't go off. Sometimes I see a little light when it should be going off. Please help!
    Scholar:
  • 67 Answers
Did you press the button next to the on/off button. Press the button under the delete 3 times you should see the Flash status on the screen. What's your firmware version for the Camera. If you press menu the select setup menu, select about it should tell you.
Posted on Jul 23, 2008
Pilot light not lighting on 420ex speedlite canon flash
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Feb 28, 2013 | Canon Speedlite 420EX TTL Flash
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
Jan 10, 2018 | Sigma EF-530 DG ST for Pentax TTL Flash
How to take a good picture in bad lightning
You can find the manual here. They have some suggestions for shooting in low light:
  • Set scene to "NATURAL LIGHT" Capture natural light indoors, under low light, or where the fl ash can not be used.
  • or set Scene t "PARTY" Capture indoor background lighting under low-light conditions.
Use a tripod if available, or brace the camera against a wall, table, or other fixed object when taking pictures to reduce blurriness.
If you don't have an object to brace the camera against, use these techniques to reduce camera shake. Press the camera button instead of jabbing at it.
Search the internet for "low light photography" for more tips. The PARTY and NATURAL LIGHT settings on your camera should boost the ISO on your camera.
Do some test shots before hand in low light situations to see what works best.
Feb 11, 2012 | FUJIFILM FinePix S2950 / S2990 Digital...
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
The camera was working fine. I imported the pictures to Picassa succesfully and turned the camera off. I then went to take new pictures and all I get is a black LCD screen and when I load into Picassa the...
The CCD is bad or the Iris is shut stuck. If it's the Iris just stuck, it might just have moisture - leave the camera in a dry place for a day. If it's the CCD - pretty much "kiss-it-good-bye". To replace the CCD is expensive - get a new camera.
Nov 02, 2010 | Cameras
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Camera dropped in water, flash broken
http://www.fixya.com/support/r3771170-phone_water_damage
Jan 01, 2009 | Canon PowerShot A70 Digital Camera
Samsung S730 No Flash
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Jan 18, 2008 | Samsung Digimax S730 Digital Camera
The colour on the EVF and LCD is pretty pink and nearly red
Yes it is. I believe Panasonic knows that the built in flash casts a very blue tint so they set the flash WB to very red to compensate. Therefore before the flash is triggered as when you watch the LCD. Some threads here even suggested adjust the WB further 2 knots to the red manually (press " up" a few times on the 4-way button to have better skin tone. Try it. The setting stays even when you turn off the camera.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Kodak EasyShare M853 Digital Camera Logo
148 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
