try and find a menu section of the system by changing the modes of operation. If you can get to the menu section there will be a language drop down section that you can highlight and save
Sounds like your video card may be overheating. Try cleaning the cooling fan and make sure there are no obstructions to the airflow. Also you could try updating to the latest drivers. Click below:
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Just make a search for samsung mp3 yp-u3j driver you want to download - say a cd ,driver or software, etc. You will find the links of webpages from where they can be downloaded. /downloadanystuff.org/ To further narrow down search, just click on the relevant category on search page - eg 'software/driver and you will be able to get Only that driver cd download. And also use drop down section for refine your search
1. PlayStation 2 systems do not handle tapes, but CDs and DVDs. No wonder you have broken it if you inserted a tape in it. 2. There is no radio in a PlayStation 2 system. 3. On a PlayStation 2 system, the button with a red dot on it is the power button, and it turns green when the power is on. 4. You cannot record, especially not on tapes, with a PlayStation 2 system. 5. You usually don't play a PlayStation 2 in the kitchen, but in the living room since it's meant to be plugged in your TV.
Here's the diagnostic : you do not own a PlayStation 2 system.
You have been ripped off by whoever sold you this piece of **** under the name of "PlayStation 2 system".
dear donya,
Internet Explorer 7
To enable or disable Java:
From the Tools menu, or the Tools drop-down in the upper right, select Internet Options... .
Click the Programs tab.
Click Manage Add-ons.
Highlight Java Plug-in.
Under "Settings", click Disable.
Click OK, and then OK again.
To enable or disable JavaScript:
From the Tools menu, or the Tools drop-down in the upper right, choose Internet Options... .
Click the Security tab.
Click Custom Level... .
Scroll to the "Scripting" section of the list. Click Disable or Enable.
Close and restart your browser.
Internet Explorer 6 and earlier
From the Tools menu, choose Internet Options... .
in version 6, click Custom Level... .
Java: Scroll to the "Java" section. (In version 6, you will find this section under "Java VM", under "Java permissions".) To disable Java, click Disable Java. To re-enable Java, click a different setting, such as High Safety or Medium Safety.
JavaScript: Scroll to the "Active scripting" section of the list. (In version 6, this is under "Scripting".) Click Disable or Enable.
download latest adobe flash player and install.
if u r using ie6, try to upgrade it ie7.
thanks,
