Question about Kicker Car Audio & Video
I have a board out of a zx 350.2 kicker amp parts number 083KX2chp the gain the vr1 knob is very lose to the touch. once you move touch it the bass goes in and out like a shortage its a one peice board the pulls out of the amp kind of like plug and play
sicaudio
  • 96 Answers
SOURCE: price check
you would need the L7 dual 4 ohm subs they cost $200 each and the zx1000 amp runs $400 each.
However, the zx1000.1 amps will barely push them (L5 1200 watt would be a better choice on that amp) so the total cost shipped with authorized kicker warranty for 1 year would be $1200.00
I do however have 1 new in box single 06S12L7 dual 4 ohm in stock for $150 shipped its under full manufacturer warranty as well. the amps you need to push the rated power for L7 subs is the zx1500.1 and they are $600 each all of these prices are nearly 1/2 of retail that kicker requires its dealers to sell at, however i am a distributor so I can sell at w/e price I want :)
I can get you into a much better sub and amp combo for less but it isn't kicker brand. I went from 4 L7 12's running zx1500.1 to each sub for a total of 6000 watts RMS and hit 151 db and switched to Hifonics subs and amps and hit 157.3 with only 2 12 inch square brutus subs and 1 2000 watt RMS class d brutus amp. Hifonics will even warranty a blown or burned sub but kicker will not because they know they have voice coil heat issues with them. I have been using the same 2 subs and single amp for 9 months now in serious street beat comps and have never had an issue other than breaking car glass, however with the kicker sub amp combo in 7 months i went through 5 subs and 2 amps and never broke a window.
I can get you the brutus amp for $350 shipped and the subs for $260 a pair shipped or $600 for the combo shipped which is 1/2 the cost of the kicker at twice the quality and sound output. Hifonics is the only company to ever win more than 150 sanctioned events in a single season and they hold the record with over 210 wins in a season
let me know what you think on the price and I will do what I can to help out.
Posted on Sep 15, 2008
MrScary66613
  • 1990 Answers
SOURCE: 12inch l7's rattle or sound really distorted on low pitch bass
You need to lower the Gain just a little.
Posted on Jan 05, 2009
Shadowmaru
  • 33 Answers
SOURCE: i turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Posted on Feb 11, 2009
etirbynnor
  • 655 Answers
SOURCE: bass sounds muddy and volume is minimum.
Hello mercedesman4,
Your setup sounds great. I had to settle for Blaupunkt in my Mercedes.
It sounds like the culprit is your enclosure. It's possible that by tweaking the settings, you could improve the sound somewhat, but having been used to the sound of a sealed enclosure, maybe not. Sealed enclosures tend to produce tighter, more accurate bass and have a flatter frequency response curve. They are also generally the enclosure of choice when looking for a SQ (sound quality) oriented setup.
Ported enclosures will produce louder bass than sealed enclosures, and maybe that's why some audio guys push them. They also allow the speaker to operate more efficiently, so you need less amp power for a given volume. Higher tuning on a ported box will get louder, but at the expense of sound quality. Lower tuning will still get louder than a sealed box, and the sound quality will be better than a box tuned higher, but still not as good as sealed. That's what I meant about tweaking the settings. You may see some improvement by setting the crossover lower, decreasing bass boost, or by turning the subsonic filter on/off. I'm no audiophile, but personally I've never been able to stand the sound of a ported enclosure, however it was tuned. Sealed just sounds better.
Hope this helps.
Posted on Mar 30, 2009
  • 10 Answers
SOURCE: i have a kicker l7 12 and a kicker 500.2 amp and
its problably grounding out check your wiring
Posted on Sep 29, 2009
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
@aol.comI have a kicker zx 1500.1 amplifier and a 15 inch L7 2ohms. Is the amp too much for it?
the amplifier is never to much for the sub. If the gain on the amp is turned up to much then that will pop the sub.
Jul 30, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I dont have the blast port wire and it wont play.where can i find the wire?
  • BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
  • Here is the manufacturer's accessory page to the remote: http://www.kicker.com/zxrc
    Here is one on eBay: http://cgi.ebay.com/KICKER-2010-10-ZXRC-AMP-AMPLIFIER-REMOTE-BASS-CONTROL-/360328112100?pt=LH_DefaultDomain_0&hash=item53e53aa7e4
    And here is a note from Kicker on how to make a control yourself for strapping multiple amps together: I have two or more Kicker SX or KX subwoofer amplifiers. I don' t want to use all those separate bass level controls. Is there a way to make them all work with a single Kicker control knob?
    Yes. You can visit your local Radio Shack or home improvement store and purchase an RJ-11 modular adapter. You then plug the sub level cables from the individual amplifiers into the adapter. Then run a cable from the adapter to a single Kicker remote knob. All amps will now work with a single knob.
    Dec 28, 2010 | Kicker SX400.2 Car Audio Amplifier
    I have a kicker 750.1 amplifier. I was playing it one day pretty loud and it cut out once the bass hit and started smoking.The gain was up about 1/4 and the bass boost was about half way. what could of...
    I would say that your subwoofer Or speaker leads have shorted out...when the bass hits as you say it drives the amp hard but if it is trying to dump power onto a shorted speaker or speaker wires it will blow the output power transistors not to mention other vital components of the power amp...i suggest you test your speaker leads with a Multimeter on the ohm setting before connecting a repaires or another amp.. to make sure there is no short on the leads and that the resistance is around 4 ohms or so depending on how you have your drivers wired...but anything lower than 2 ohms will cook an amp! you can normally pick up a meter from anywhere for around $10..
    Jan 14, 2010 | Kicker (ZX750.1) Car Audio Amplifier
    Volfenhag amp adjustments
    Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
    Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
    Gain makes subs go crazy when turned up
    HI DUDE UR AMP IS TO POWERFULL FOR THE SUB ... .... LOWER DOWN BASS IN UR PLAYER ... AND AMP .... TRY ADJUST BACK THE TUNE ... IT WILL B FINE ....
    Apr 14, 2009 | Kicker KX800.2 Car Audio Amplifier
    Constant sound from subs
    I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
    Jan 09, 2009 | MTX RT2200 Car Audio Amplifier
    Bass control stopped working
    on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
    Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
    Kicker ZX 750.1
    I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
    Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
    Car Audio & Video Logo
    Top Kicker Car Audio & Video Experts
    Professor_V
    Professor_V
    Tygh Duval
    Tygh Duval
    hoyzee1
    Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
