Question about Pentax K100D Super Digital SLR Camera
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT NEED TO BE CHANGED ON THE CAMERA TO MAKE THEM WORK. I SPENT SEVERAL HOURS IN THE BOOK TRYING TO FIGURE IT OUT AND AM MORE CONFUSED NOW THAN WHEN I STARTED. THANKS ROY
  • Just Gort
    Just Gort May 11, 2010
    Pentax rules!!
1. Set manual focus
2. In Menu -> custom settings ->Using aperture ring = 2
3. When taking photo, focus, set aperture and press green button to set exposure time. Then press shutter.
works fine with my antique SMC Pentax lenses.
Posted on Jun 30, 2009
    Problem Solver:
  • 18 Answers
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Posted on Jul 26, 2008
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
Quantray mc auto zoom 70mm-210mm
Yes, if it is a K style bayonet, it will work - Pentax allows any K mounted lens to work with all their cameras from the K1000 from 1976 to the present... BUT - don't expect auto anything... including zoom or metering... but it should allow you to use it at least... Assuming the Lens is a K mounted lens... (you can't use it if it is a Nikon F or AI style, or Canon, or Minolta, which all use a bayonet style mount...)
Jun 24, 2014 | Pentax Cameras
I have a Pentax k1000, and was given a few vivitar and olypus lenses. They do not fit the camera. What can I do?????
Vivitar makes lenses with a variety of mounts. Lenses with the Pentax K-mount can be used on the K1000, lenses with other mounts can not.
Olympus lenses will not mount onto a Pentax camera.
You can sell the lenses, give them to someone with the appropriate camera(s), or use them as paperweights.
Nov 21, 2012 | Pentax K1000 35mm SLR Camera
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
I recently bought a Sigma zoom 120-300mm lens for my K110. This lens has an aperture ring , but no auto lock A. How do I use this lens without this feature??
If the lens has no A setting then it is incompatible and cannot be used. There is no way around this, sorry.
Sep 26, 2010 | Pentax Cameras
Pentax K1000 35mm SLR Camera Lens will not turn or focus= stuck
Impact damage??? remove the lens and check the barrel for straightness. also the rear lens element must be perfectly straight. some of the latest lenses have a plastic helical gear that can be tapped out with a light hammer and a piece of wood ( 1in X 4in. ) used on the high end of the rear lens, if impacted.
Oct 16, 2009 | Pentax K1000 35mm SLR Camera
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
Jun 05, 2009 | Pentax MZ-60 QD 35mm SLR Camera
Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Feb 12, 2008 | Pentax K10D Body Only Digital Camera
Pentax K1000 camera
VGDHDTH HNTFHDT VGJFT GJ ME MAY
Dec 19, 2007 | Cameras
Will this lense fit on my camera?
You can have the 28-300 temron lens with beynout mount of pentax it will deffinaitly works like another lens manually , because af lens has a option of manual also so it will be suitable
Oct 01, 2006 | Tamron AF28-300mm XR Ultra Zoom for Pentax...
Pentax K100D Super Digital SLR Camera Logo
257 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
